Viper Truck Club of America
Go Back   Viper Truck Club of America > Viper Truck SRT-10 Discussion > General Discussion
Register Members List Timeslips Calendar vBGarage FlashChat Mark Forums Read
General Discussion General Discussion
Reply
Thread Tools Display Modes
  #21
Old 10-30-2009, 04:24 PM
FSTJACK's Avatar
FSTJACK FSTJACK is offline
Administrator
Member Number: 2
Send a message via AIM to FSTJACK
Good advice here.................
Quote:
Originally Posted by FerrariTruck
pull the belt of and then start the motor to isolate the noise...Hopefully it does go away when you pull the belt off.
P.s. dont run the motor without the belt for more then a minute
__________________
04 Ram SRT-10 #593, Silver, Under construction, TT TH4oo W/Brake, 4 Link, Caged Certified to 8.50. Coming to a dragstrip near you, not very soon..........
04 Ram SRT-10 Red..... Blown, Sprayed x 2, McLeod Twin, Locker, Hoosiers, Bogarts. 536 CI. all bore, Crower, JE, Jeff Morey heads, billet mains, main cap girdle, Daley external oil pump, Exotic Engine Design Built. Pectel ECU, might get me into the high 12's........
69 Chevell B/Gsupercharged, Injected, certified to 7.50
  #22
Old 10-30-2009, 04:32 PM
LitemUp's Avatar
LitemUp LitemUp is offline
VIPER POWERED
Member Number: 146
Mine does the same thing
http://videos.streetfire.net/video/S...-10_123500.htm
__________________
2004 Build #2666
Paxton SC, Keyed Crank, ATI Harmonic Balancer, Snow Performance Stage 3 Meth Kit, X-Metal handling kit, Gen X Shifter, Magnaflow cat-back, Caltracs, HID's, Tinted tails, Laserlite bed cover, and Bedrug
  #23
Old 10-30-2009, 05:23 PM
05QCSRT10's Avatar
05QCSRT10 05QCSRT10 is offline
Almost Senior Member
Member Number: 11017
Quote:
Originally Posted by LitemUp
Yours is definitely fu*ked up . Is that a Escort 9500I hiding up there
__________________
2005 Dodge Ram 1500 SRT10 Quad Cab
Built 2/17/05 at the 08th hour
Mods ~ SCT Tuner from Torrie at Unleashed Tuning, Triple Pod, Performance Gauge, Air/Fuel Ratio Gauge, Lowering Shackles, Exhaust Cutouts and a K&N Filter.
  #24
Old 10-30-2009, 07:43 PM
LitemUp's Avatar
VIPER POWERED
Member Number: 146
Quote:
You are correct Sir.
__________________
2004 Build #2666
  #25
Old 10-30-2009, 08:43 PM
flchub flchub is offline
VIPER POWERED
Member Number: 1320
its either the idler pulley or the tensioner pulley both are easy to replace
__________________
731 hp 702 tq 14.5lbs of boost 92 degrees inside/outside ,NO race fuel 93 0ctane only with NO timing added,custom paxton,ported heads,dual bosch fuel pumps,80lb injectors,ati balancer,coated ross pistons,k1 rods,coated mains,270 comp cam,hardened push rods,crower springs,home depot, tuned by torrie spelling aka unleashed
Best time to date - 11.89 - 120.67 it was only my first pass On O.E.M. continentals
WORLD RECORD HOLDER(but really who cares?), RAN AT ROCKINGHAM,NC 10/2009
  #26
Old 10-31-2009, 05:42 AM
SANTEEN's Avatar
SANTEEN SANTEEN is online now
VIPER POWERED
Member Number: 10712
Quote:
__________________
Steve
2006 Mineral Gray QC 590whp/573wtq
Paxton S/C, Racetronix 65lb injectors, Kenne Bell Boost-a-Pump, Magnaflow catback, JMB catless mids, SCT tuned by Torrie at Unleashed Tuning, X Metal TB, AEM Air/Fuel gauge, 170 T-stat, GM solenoid conversion, Belltech rear leveling shackles
  #27
Old 11-04-2009, 08:34 AM
kickinassrt-10's Avatar
kickinassrt-10 kickinassrt-10 is offline
VIPER POWERED
Member Number: 10497
while driving the truck this morning a left a light with moderate acceleration to about 40-45 mph, then cruised at that speed... I lightly let off the gas and back on and the truck had a rattling sound coming from it for about 5 seconds 2 times...1 time while letting the off the gas pedal and once again applying the gas pedal... I also noticed it faintly as a I came to a stop several minutes later...
I have not been able to get it to do it again...could this be a cause from the pullies?
I also located pullies from autozone for about $15 are these quality pulley's?
__________________
SCT Tune, Cat delete, K&N, Magnaflow cat-back, 2" drop, HID, smoked out rear tail lights (Carl ccfeyh) Kenwood Radio, Infinity Kappa perfect speakers powered JL Audio e4300, JL Audio 10"W3 powered by JL 250/1
ATF Speed Tranny
  #28
Old 11-04-2009, 11:33 AM
VIPER POWERED
bumpity bump??
__________________
ATF Speed Tranny
  #29
Old 11-04-2009, 11:49 AM
Haterade's Avatar
Haterade Haterade is offline
Member
Member Number: 2571
i had the same problem with my truck as did the previous owner. he had the belts replaced and that helped for a little bit. dealer told me one of my pulleys was bent (??) and not quite in the right spot. they put everything back where it belonged and that helped for week or so. it always seemed worse in the colder weather.
i don't have the truck anymore but always wondered what it was that caused that noise.
__________________
#1987 out of 3057, Built 5/6/2004 at the 10th hour (SOLD - 8/21/2009)
  #30
Old 11-04-2009, 11:57 AM
VIPER POWERED
I'm in the same boat right now....
__________________
ATF Speed Tranny
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin Version 3.5.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors 1.0.4
This site is supported by its members, vendors, and administration. Vtcoa.com is in no way affiliated with Daimler Chrysler. Dodge, Viper,Ram SRT-10, the Viper logo and likeness are registered trademarks of Daimler Chrysler. The contents of this site are owned by Vtcoa.com and may not be used or reproduced without the express written permission of the Administrator.
