Do I have a 2003 Dodge Ram SRT10 or not
conqurtheviper
not sure what happened. thought I posted this new thread. just isn't showing up.
I picked up a RamSRT10 two days ago. She is a bonified RAMSRT10. I inspected it through and through.
The vin # is 1d7ha16k63j662670.
Out of boredom I ran the vin with Comprehensive VIN Decoder. But their information came back showing the vin belong to truck assembled in St. Louis, and that it had a V6
Can anybody advise me as to wtf is up with this?:dontknow:
NO.... not even close
Equipment Listing
VIN 1D7HA16K63J662670
Vehicle Description 2003 DODGE RAM 1500 REG. CAB PICKUP
Monotone Paint
136 Amp Alternator
600 Amp Maintenance Free Battery
4 Wheel Disc Rr Anti-Lock Brakes
Front Height Adjust Shoulder Belts
Next Generation Front Air Bags**
Passenger Air Bag On/Off Switch
Black Vinyl Floor Covering
Passenger Assist Handle
Behind the Seat Storage / Bin
All 4-Speed Automatic Transmissions
3.55 Rear Axle Ratio
Corporate 9.25 LD Rear Axle
Tinted Glass Windows
Rear Fixed Window
Rear View Day/Night Mirror
Manual 6 x 9 Black Mirrors
Air Conditioning
Dash Liner Insulation
Route 29 - UP, Council Bluffs, IA
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
STANDARD EQUIPMENT
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Halogen Headlamps
Cargo Lamp
Bright Rear Bumper
Gray Upper Fascia
Bright Front Bumper
Front License Plate Bracket
Bright Grille
Black Windshield Moldings
Dodge Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
Front Air Close Out Panel
26 Gallon Fuel Tank
LT. Almond Pearl Metallic Clear Coat
4 Speakers
Power Rack and Pinion Steering
4-Spoke Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Full Size Spare Tire
Tire Carrier Winch
P245/70R17 BSW All Season Tires
17" Steel Spare Wheel
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Build To U.S. Mkt. Specifications
GVW Rating - 6750#
U.S. Dealer Retail
Zone 66-Orlando
Two Wheel Drive (2WD)/(4X2)
6 FT. Cargo Box
Regular Cab
1500 Series
Vehicle Order Tracking
U.S. Specifications Label
Florida Ship to State Code
Florida Sold to State Code
Cloth 40/20/40 Split Bench Seat
Taupe
Convenience Group
ST Value Group
3.7L Eng(EKG)/4Spd A/T 45RFE(DG4)
Multi-Speed Auto 45RFE Transmission
Lock-Up Torque Converter
All Gas Engine
3.7L V6 Engine
All Vehicles W/O Power Mirrors
50 State Emissions
EVAP Control System
Auxiliary Transmission Oil Cooler
Speed Control
OPTIONAL EQUIPMENT
Current Generation Eng Controller
All Radio Equipped Vehicles
AM/FM Compact Disc Radio w/Chgr Ctrl
Fixed Long Mast Antenna
Tilt Steering Column
Michelin Brand Tires
17X8.0 Steel Chrome Clad Wheels
All Steel Wheels
Center Hub
Manuf Statement of Origin
2 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAM: DR TRACKING: 20802T12 MY:2003
Customer Preferred Package 2TA
Customer Preferred Package 22A
SXT Group Discount
Customer Preferred Discount
Waterbase Paint
Paint Order Code
However, if you have a Viper Motor in it...... Drive it like you stole it!!!!
Vj
it is really a SRT-10. It would be insane to clone it with all moving parts as that of the real deal.
Well, I'm pretty sure they didn't make them in '03.
So i'm gonna go with no.
Your vin should start with 3 instead of 1 I believe as well. 3 denotes Mexico, 1 denotes USA.
It also states indeed that its an 03'.
Pics of truck and interior/engine bay?
Mine was made in november 2003, so a few were made in 03, mine was #50.
I'll check later but ViperJeff already confirmed by build info...How's the back doing Scott.?
All parts match up (from full interior, brakes, rear end, tranny, motor). I just tried to load some pics in a album but it failed (said something about a security thing). Will try again though.
Go to photobucket and upload pics from there to here using img code.
I'm not trying to be an ass, however, it's not a factory RAM SRT-10. THERE HAVE BEEN MANY CONVERSIONS OUT THERE. HAPPY THAT YOU FOUND ONE OF THEM, THEY ARE STILL VERY COOL... CONGRATS (not yelling, just making a point)
VIN PLATE DECODING INFORMATION
1​
Country of Origin1 = Built in U.S. by Daimler Chrysler Corporation
3 = Built in Mexico by Daimler Chrysler de Mexico
2​
AssemblerB = Dodge
D = Dodge
3​
Vehicle Type2 = Incomplete with Side Airbag
3 = Truck with Side Airbag
6 = Incomplete without Side Airbag
7 = Truck without Side Airbag
4​
GVWR & Pass. SafetyH = 2722-3175 kg (6001-7000 lbs)
5​
Vehicle LineA = Ram Pickup 4x2
6​
Series1 = 1500 (DR1, DR6)
7​
Body Style6 = Conventional Cab (61, 62)
8 = Quad Cab Full Rear Doors (41, 42)
8​
Engine H = 8.3L 10 Cyl Viper
(Yours came with a 3.7L Eng(EKG)/4Spd A/T 45RFE(DG4))
9​
Check Digit 0 = Check Digit
10​
Model Year 4 = 2004
5 = 2005
6 = 2006
11​
Assembly Plant G = Saltillo
J = St. Louis North
S = Dodge City
12 thru 17​
Vehicle Build SequenceModel Year Assembly Sequence
I would be leaning more toward the side of the truck was totaled, fixed and used a different vin and title. If you want to check the vin, open the hood. on the passenger side next to the headlight is a metal plate welded to the core support. Might have to remove the headlight to see it. Check the vin there and see if it matches.
This is what it looks like, and if the vin doesnt match, run this vin. If it does match, you either have a clone, or a SRT that was badly wrecked and rebuilt with another cab and nose. The inner rail this is welded to is welded to the cab as well.
