when you back into the wet box, make sure you put it back in drive.....
hey...i've seen it done...just saying
You know, I didn't even think of Tow/Haul mode. Should I be doing that even in the 1/8th mile?wyoramsrt-10 said:I put about 18 lbs in mine, launch from 1800-2000 rpm, wait for that neck snaping shift into second, and don't forget to put it in tow haul mode so you don't shift into overdrive before the finish line. A line lock is a good investment if you race it a little bit. The side gears & spider gears have been know to explode from power braking.
I always have and was told to have it in tow/haul. It raises the shift points in 1,2, & 3rdSANTEEN said:You know, I didn't even think of Tow/Haul mode. Should I be doing that even in the 1/8th mile?
