poppopmadman
Please check your pinion angle after you lower your Ram SRT10.
My Bad - I should have checked!! The pinion angle was off.
I lowered my SRT10 with the X-Metal lowering blocks in rear.
I was at 0 degrees and had to add a set of 4 degree shims to get pinion angle right.
I will get a machine shop to cut blocks the degrees where I need them.
They worked great cruising around and hitting it once in awhile but found out today after I was working on Ram Rod setup. I will test to see if this will help my Ram Rod bar this week.
Boomer should be able to help you figure your pinoin angle!!
Maybe Boomer can sell them at different angles...
