RedSrt007
Due to my shifting problems, something else which will be done while the transmission is out is a complete fluid change. I contacted Tremec (who makes our transmissions) and also T56rebuilds, and they both said to get the fluid out ASAP. I asked them why the factory fluid needs to be removed, they said it 'gums up the internals' due to the Castrol Syntorq (the stuff these trucks come with) being more of a gear oil then a transmission fluid. They both recommended Mobil 1 Full Synthetic ATF. Since the actual manufacture of the T56 told me this, I am convinced. I also found this article which seems to be helpful also. I will be changing the fluid out tonight, and will keep everyone posted.
Thanks
Patrick
"THE Word" on 1998-2002 Manual Tranny Lubricant
The question about whether one should run synthetic ATF or even a non-ATF gear lube in the f-body's Borg-Warner/Tremac 6-speed tranny has been bouncing around. Mark DeCarlo, co-organizer of CNYF, has tracked down the answer. Mark reports....
"I spoke with the T-56 expert at Tremec. He said that the Mobil 1 Synthetic ATF is an excellent choice for the T-56, PROVIDED that the T-56 is a 1997 model or newer.
DO NOT run the synthetic ATF in the pre-1997 T-56 units. It will destroy the paper on the blocker rings. And do not run it in a manual trans with brass blocker rings either, because it will ruin those also.
Tremec changed the blocker rings to the carbon fiber type for the 1997 model year and synthetic ATF will not degrade these.
I asked about the GM SynchroMesh and he said it was good, but not quite as good as the Mobil 1 Synthetic ATF. The SynchroMesh fluid comes in the Tremec 3550.
He said you should have no problems running the Mobil 1 Synthetic ATF in the T-56.
Notice how I keep saying "Mobil 1 Synthetic ATF". He said stay away from the other aftermarket racing type synthetics, as they have extra additives that can degrade components.
I asked about the Castrol Syntorq gear lube. He said you could use it (and they used to in the Viper), but you will encounter hard shift in cold weather and cold clash.
Thanks
Patrick
