Automatic transmission fluid and filter change instructions
JTS VENOM PERFORMANCE
Preferred Vendor
SRT10 heaven
REMOVAL
(1) Hoist and support vehicle on safety stands.
(2) Place a large diameter shallow drain pan
beneath the transmission pan.
(3) Remove bolts holding front and sides of pan to
transmission
(4) Loosen bolts holding rear of pan to transmission.
(5) Slowly separate front of pan and reusable gasket
away from transmission allowing the fluid to
drain into drain pan.
(6) Hold up pan and remove remaining bolt holding
(7) While holding pan level, lower pan and gasket
away from transmission.
(8) Pour remaining fluid in pan into drain pan.
(9) Remove screws holding filter to valve body
(Fig. 90).
(10) Separate filter from valve body and pour fluid
in filter into drain pan.
(11) Dispose of used trans fluid and filter properly.
INSTALLATION
(1) Position a new transmission oil filter onto the
valve body.
(2) Install the screws to hold the filter to the valve
body. Tighten the screws to 4 N·m (35 in.lbs.).
(3) Clean the gasket surfaces of the transmission
oil pan and transmission pan rail.
NOTE: The transmission pan oil gasket is reusable.
Inspect the sealing surfaces of the gasket. If the
sealing ribs on both surfaces appear to be in good
condition, clean the gasket of any foreign material
and reinstall.
(4) Position the oil pan gasket onto the oil pan.
(5) Position the oil pan and gasket onto the transmission
and install several bolts to hold the pan and
gasket to the transmission.
(6) Install the remainder of the oil pan bolts.
Tighten the bolts to 13.6 N·m (125 in.lbs.).
(7) Lower vehicle and fill transmission. (Refer to
21 - TRANSMISSION/AUTOMATIC/FLUID - STANDARD
PROCEDURE)
STANDARD PROCEDURE - TRANSMISSION
FILL
To avoid overfilling transmission after a fluid
change or overhaul, perform the following procedure:
(1) Remove dipstick and insert clean funnel in
transmission fill tube.
(2) Add following initial quantity of Mopart ATF
+4 to transmission:
(3) Apply parking brakes.
(4) Start and run engine at normal curb idle
speed.
(5) Apply service brakes, shift transmission through
all gear ranges then back to NEUTRAL, set parking
brake, and leave engine running at curb idle speed.
(6) Remove funnel, insert dipstick and check fluid
level. If level is low, add fluid to bring level to
MIN mark on dipstick. Check to see if the oil level
is equal on both sides of the dipstick. If one side is
noticably higher than the other, the dipstick has
picked up some oil from the dipstick tube. Allow the
oil to drain down the dipstick tube and re-check.
(7) Drive vehicle until transmission fluid is at normal
operating temperature.
(8) With the engine running at curb idle speed, the
gear selector in NEUTRAL, and the parking brake
applied, check the transmission fluid level.
CAUTION: Do not overfill transmission, fluid foaming
and shifting problems can result.
(9) Add fluid to bring level up to MAX arrow
mark.
When fluid level is correct, shut engine off, release
park brake, remove funnel, and install dipstick in fill
tube.
I believe the correct amount of ATF+4 is 8-10 quarts
Dammmmmm - what you been drinkin Tony :dontknow: It sure put some fire under your typing fingers. :p :D
Stinker said:
te he:beerglass: =:cheers: =:vollkommenauf:
LOLOLOL
Ahhhhh, that answered my question. You been drinking thatstuff again :rock:
Stinker said:
I jsu be a typing little bitch tonight!LOLOL
bWAHAHAHAHAHA - i KNOW THE fEELING :D :D :star: I'm a typing little bitch every night :D :p
(Fig. 90).
If I were doing it, there'd have to be
an 8A: Clean up spilled trans fluid so you don't slip and bust your ***. :p
If you decide to through a Mag-Hytec pan on the tranny bottom, then it will be 17 quarts. Mine was well worth the money (240) and gives me peace of mind. Anyone else put an aftermarket pan on?
