moparracing
after much research & on advice from a member "shade", i decided to give the following pads a try:
for 2005-2006 Model: ram srt-10
Centric Posi-Quiet Extended Wear pads offer a stable friction level across a wide temperature range. Low dust, long pad & rotor life, low noise, w/OE designed shims to reduce pad vibration and squeal. Not a track pad.
63-106-1085 Fronts-$70
63-106-0702 Rears-$40
they can be gotten from:
David Zeckhausen
Owner, Zeckhausen Racing
(973)761-5054
www.zeckhausen.com
these pads eliminated the brake squeak & greatly reduced the brake dust with no difference in braking quality...... i also followed his brake bedding procedure with good results:
http://www.zeckhausen.com/bedding_in_brakes.htm
the only issue had was on installing the front pads, they required a little filing to fit properly (easy to do), i've attached a pic showing where i had to file....... this is the same issue that guys who bought the autozone #1085's had...... these pads are twice the cost of what the autozone pads are & less than the ebc pads, but completely solve both issues we all have dealt with.... David Zeckhausen is awesome to deal with too !!!! you won't be disappointed !
David Zeckhausen
(973)761-5054
www.zeckhausen.com
