Chuck B
I've been working on a Mod list as of late and one of the mods includes installing a REAL oil cooler. One of my dealers is www.raceroffroad.com so who better than to help with a customized fabrication and engineering. These guys put together, from scratch, some amazing offroad machines.
If you look at our oil cooler its also an exchanger. Oil and coolant flow through the cooler. I can only guess that the reason Dodge put coolant through the oil cooler was to aid in getting the oil up to temperature quickly after startup. For those in colder area's it makes sense but for those of us in the desert SW....I don't think so. My truck struggles to keep coolant and oil temps near 200F during summer here in Phoenix.
The other thing you'll notice is air flow is greatly influenced by the factory cold air induction setup. The factory setup funnels cold air to the factory air box as well as down and around to the oil cooler. I know many here have removed the plastic on the hood/grill but doing so makes the oil cooler less effective though many have reported great reduction in underhood temps.
The Plan....fabricate a new oil cooler with mounts for clean straight forward install. Key for straight forward install would be to utilize the factory oil cooler lines. Ideally, simply disconnect both at the factory cooler and reconnect to the aftermarket oil cooler. Then simply cap off the factory cooler leaving on the coolant to flow as original.
Racer Offroad has already taken measurements, thread size and pitch and will CAD a design then send out to a manufacturer for build. They recommended a Turbo Innercooler style cooler for this application.
My thoughts....Installing it on the passenger side of the radiator allows use of factory oil lines, good airflow with removal of factory CAI on grill but when cold weather arrives you can simply reinstall the factory CAI back on the grill greatly reducing air flow over the cooler.
Obviously doing a one off is going to be expensive. Ideally I'd like to share costs with others but regardless pending any reason NOT to go this route I'm moving forward with my first stage of modifications.
Your thoughts? Interests? Thanks!!
