Scan Gauge II by Linear Logic. I thought I would start a thread on this since we started to talk about it in another thread somewhat related.
Attached are some pictures which don't give the color justice. You can select multiple colors. Anyhow, on to the real 'stuff'. :rock:
The gauge will monitor:
CLSD LOOP
OPEN LOOP
Intake Air temp
Water Temp
Fuel Pressure
Gallons per hour (or liters)
Ignition timing
Engine Loading
MPG/KPG
MPH/KPH
MAP - Manifold Absolute Pressure (is PSI or Kilo pascals) ** At WOT pressure can be as high as 15 PSI or more with forced induction.
RPM
Voltage
It has a TRIP mode
Max Speed
Max Coolant temp
Max RPM
Average speed
Average fuel Economy
Trip Miles
Trip Elapsed time
Trip Fuel used
Fuel used since last fill up
Fuel remaining
Distance driven
Distance remaining
Time driven since last fillup
Time remaining before tank empty
--(Yes, some of this redundant for the SRT but still good info)
It will read ODB2 codes AND clear them for you. Even with the engine off.
You can switch vehicles with it (unlike some Superchips or Hypertech programmers).
Cost me 165 dollars delivered (Ebay purchase). I wrote to them to see if they want to be a forum vender and/or give a group buy option. So stand by if interested. :congrats:
I have not used all modes with it so I can't confirm or deny how well they work yet. However, so far so good. It has read two of the most arguable difficult engines/computers so far with my Hemi and Viper engines.
It simply plugs into your ODB2 port underneath the steering wheel. Power is supplied from the port, no batteries or 12 volt cords needed.
http://www.scangauge.com/
CLSD LOOP
OPEN LOOP
Intake Air temp
Water Temp
Fuel Pressure
Ignition timing
Engine Loading
MPG/KPG
MPH/KPH
RPM
Voltage
It has a TRIP mode
Max Speed
Max Coolant temp
Max RPM
Average speed
Trip Miles
Trip Elapsed time
Trip Fuel used
Fuel remaining
Distance driven
Distance remaining
