Racetronix 65 lb injectors for sale. These are the shorty versions that David Weaver recommended. However, looking at them, I don't believe they will fit thru the Roe base, even though David got them through somebody's SC base. Talking with Sean (Roe) I should use the longer version. Nevertheless, I have not used them. They are flow matched and would be a good upgrade for someone without the Roe base.
[FONT=Arial,Helvetica][SIZE=-1]Part # INJ-GAS-0002 (S107FM) Part # 107962[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]Static Flow Rate: 60 lb/hr @ 43.5PSI (300kPa) = 630cc/hr (sold as 65lb/hr by some vendors) [/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]Coil Resistance: 12.5 Ohms / High Impedance / High-Z(No ECM driver modifications required)[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]Gain: 0.11ms/mg, Offset: 0.055ms, Turn on time: 1.14ms @ 14VDC, Turn off time: 0.85ms @ 600KPa[/SIZE][/FONT]
[FONT=Arial,Helvetica][SIZE=-1]Wide angle spray pattern[/SIZE][/FONT]
http://www.racetronix.com/S107FM.html
I paid 550 for them.
Will sell for 400 + shipping. Or any good trade, I am easy. (not that easy Mikey)
