noid
So I had a new set of rear leafs from Hotchkis sitting in the garage. I also had a new set of rear leafs off of a QC SRT-10 ( Thanks Fast Fred ) right next to the hotchkis for comparison. Obvious differences were the arch of course and the curl at the ends of the leafs. And overall thickness of the metal leafs. The curl at the end of the stock leafs start under the then wrap over the bushing. The Hotchkis are opposite. I am guessing that Hotchkis did this to get more drop without sacrificing strength. We measured from from the front of the center point to the pin centered in the leaf. Everything looked good. We installed the Hotchkis leafs with the Caltracs bushing. And the shorter Bilstiens from Hotchkis. Got one side mounted up and noticed something wrong. How is the caltracs going to work with the curl going in the opposite direction as the OEM leaf. So we made a phone call to someone we knew had a Hotchkis/Caltracs set up on his Ram. He advised use that in order to get it to work we would have to flip the main leaf. Of course this brought up some doubts but we were assured this is what the racers are doing that run Hotchkis and Caltracs. So knowing that I could always go back if things did not work out or if I did not like it we proceeded. In the end after getting it all bolted up we noticed that the axle now sits about .5"-1" further back from the center of the bump stops. Double checked the leaf pin to make sure it was in the center hole in the perch's. It was were it should be. With the tires on it is perfectly centered in the wheel well.
So onto the test drive. The trucks ride was much improved over Hennessey Jr's kit. It was a little stiffer but not harsh. Feedback seemed to better. So far I really like it.
Because we had to flip the main leaf to get the Caltracs on. It actually raised the rear about 3/4" giving me a slight rake. Which I actually like more than the level look. As far as towing is concerned. I do not tow with my truck because I have nothing to tow. So I do not recommend this setup if you plan on towing or you have airbags. Know I just need to put the front Hotchkis springs in.
