FerrariTruck
I stop using mobil early on due to the motor in the truck sounding a lil noisy.
I swithced to castrol motorsport 10-60w (used in all the BMW M motors) and
that really made the motor quiet down a bit. But do to the price of it at
around $9 bucks a liter i had to find an alternative..
So i did some looking around on mobil website I found this 15 50 blend. What
really caught my eye is the zinc level in this oil is around 1200-1300 ppm
which is almost unheard of these days. So i shot down to walmart after
looking it at all the chain autostores and to my luck they had a case of it
left:rock: its $22 for 5quart container
I will be running mobil 1 again, check the link for yourself.
its even recommened for engines during the break in period(i.e. zinc level)
as well as for supercharged or turbo charged motors. i'm sold
https://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_15W-50_.aspx
Mobil 1 15W-50 exceeds warranty requirements for gasoline engines where an API certified oil is specified. It meets:
API SM/SL
Requirements for Diesel Powered Vehicles where an API CF or API CD is recommended
Provides extra anti-wear additive for older vehicles
Mobil 1 15W-50 is formulated with SuperSyn, an extra-high viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications such as towing, hauling and racing. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired.
Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
For more information, see the Mobil 1 15W-50 Product Data Sheet and Material Safety Data Sheet.
Product Description
Mobil 1 15W-50 is the most advanced performance synthetic engine oil designed to provide the cleaning power, wear protection and performance reserve to keep engines running smooth and clean.
Features and Benefits
Mobil 1 15W-50 is formulated with SuperSyn, an extra high-viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired. Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
Key features and benefits include:
Features
Advantages and Potential Benefits
Fully synthetic formula with SuperSyn Technology Helps prevent deposits and sludge build-up to enable long engine life Excellent overall lubrication and wear protection performance for all driving styles
Outstanding thermal and oxidation stability Outstanding performance during the maximum oil change interval recommended in a vehicle’s owners manual
Extra anti-wear additive Extra protection for severe service
Applications
Mobil 1 15W-50 is recommended for all types of modern vehicles, including high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks.
Mobil 1 15W-50 is recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required in newer generation vehicles
Mobil 1 15W-50 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Back to Top
Specifications and Approvals
Mobil 1 15W-50 meets or exceeds the following industry specifications:
API SM,SL,SJ,EC,CF
Typical Properties
Mobil 1 15W-50
SAE Grade 15W-50
Viscosity, ASTM D 445
cSt @ 40º C 131.2
cSt @ 100º C 18.1
Viscosity Index, ASTM D 2270 154
Sulfated Ash, wt%, ASTM D 874 1.21
HTHS Viscosity, mPa•s @ 150ºC ASTM D 4683 4.50
Pour Point, ºC, ASTM D 97 -39
Flash Point, ºC, ASTM D 92 235
Density @15º C kg/l, ASTM D 4052 0.87
API SM/SL
Product Description
Features
Applications
Back to Top
API SM,SL,SJ,EC,CF
Typical Properties
Mobil 1 15W-50
SAE Grade 15W-50
cSt @ 40º C 131.2
cSt @ 100º C 18.1
