Factory Radio with headphone/aux jack ?
VENOMOUS1 RACING
Wacko Waco,TX
I have the factory nav unit in my 10 and have grown attached to Pandora in other cars that I can simply plug my phone into and jam! What radio do I need to do this? RB4, RB1,
I would like the one that can play DVDs as well. USB port would work as well. Or some known way to play my iPhone through my older radios.
Wesalbert?? You out there bro? Lol
Thanks in advance , and no I don't want aftermarket. :)
you can build your own kit thats what i did and use my cellphone to plug into it and listen to pandora through the radio dont know if i have any pictures of mysetup i will check
ok i cant find pictures of the one i did in the 10 only the setup i did in the wife's avalanche i will try taking a picture when i go out tomorrow but basically hooked up an aux input into the antenna
I could never find a set up that will play through the stock radio that's why I bought an aftermarket 1
i will take a picture of mine tomorrow i think my setup looks fairly factory and works quite nicly have used it to drive from NY to TX and back and worked great :)
Look this up on ebay
ISIMPLE ISCH73 IPOD/ IPHONE AUDIO INPUT INTERFACE KIT FOR DODG/ CHRYS/ JEEP NEW
ok took some pictures today while i was out there ignore the bit of clutter lol.
thats how i set mine up the cord goes up to the windshield since thats where i usually put my smart phone and have my pandora radio/navigation of my cell that i use :)
Thanks bro! So you wired this plug into your radio? How? Or is there an adapter?
My radio is different but I would be happy with a setup like you're describing :)
its a hardwired fm input basically takes a hot and ground wire for power then you unplug antenna plug this into antennna and antenna plugs into this. when switch is on radio is dead and plays what ever is plugged into the aux port off radio works instead. i will find the kit and post it
[ame=http://www.amazon.com/gp/product/B001QBG614/ref=oh_details_o06_s00_i00]Amazon.com: Scosche FM-MOD02 Universal Audio Input FM Modulator for iPod, Satellite Radio or Portable Music Player: MP3 Players & Accessories[/ame]
thats the kit i bought then i just got some antenna adapters at walmart. it has a remote block you can see i took it apart and carefully cut and drilled the holes in that little piece of plastic and fit them in it since its easy/cheap to replace if i ever get rid of that port there in the future.
just noticed amazon is saying there is an issue with vendor on that one i did this probably 6 months ago i just copied the one from my previous order but sure you can find it else where :)
I use an FM transmitter. Works pretty well and charges my I-Phone while its plugged in. Get a Griffen or a Belkin if you go that route. I still want an aftermarket with bluetooth though.
My radio gas Bluetooth/u connect! Could that interface? Anyone know
Thats cool as hell! But seems too cheap for everything that it does. I like the look of it being stock!
