I’m looking for the tool online to compress the springs I got for my cam kit from Venomous1 Does anyone know what tool I would need exactly. For the 2004
Are you compressing springs with the heads on or off? There is nothing special required for these engines BUT you get what you pay for with a Valve Spring Compressor. I have no idea what spring pressures you are dealing with but the more expensive compressors won't collapse or bend under load like the cheapies will. You may be able to rent one.
I will be doing them with the heads on. yea not really looking for a cheap tool. I just want to make sure it does the work correctly
Gotcha' I wasn't suggesting you were looking for a cheap tool just giving you a heads' up there is some real crap on the market these days. It LOOKS like it should work, but doesn't. Years ago, I got a little aggressive with valve lash and rpm and snapped a valve-spring on my 426 Hemi. Fortunately it didn't drop the Valve. I ended up making my own tool for swapping out the spring. Good luck.
