2005ViperRam
Well-Known Member
- Joined
- Oct 13, 2012
- Messages
- 224
- Reaction score
- 432
I am doing the suspension on my 2005 QC SRT-10.
After getting all the items back from the sandblaster and powdercoater it is now getting put back together.
Here is my next question:
My original Lower Control Arms use ball joints are kept in by a retention flange (basically metal bent over). The new Moog K7411, https://www.rockauto.com/en/moreinfo.php?pk=504339&cc=1431796&pt=10070&jsn=13) uses a snap ring. This where I’m getting confused.
Moog calls LD (Light Duty) the ones with a flange. It calls HD (Heavy Duty) the ones with the snap ring: https://www.rockauto.com/info/11/DYK10_104_ENG-R.pdf
The 2005 SRT-10 service manual torque specs are:
LD - 38lbs + 90 degrees
HD - 100lbs
(See attached picture)
So what am I torquing them to since I removed the retention flange ball joint, and replaced them with a snap ring ball joint?
HD - 100lbs
