CHRIS TRAPP
- Joined
- Mar 10, 2025
- Messages
- 1
- Reaction score
- 1
anyone make a mopar labeled battey for these group 65
Search for restoration batteries and see if any come up. There's a company that offers group 24 covers - called mancini racing maybe contact them for a lead.anyone make a mopar labeled battey for these group 65
No it's not - it's been replaced but i have the original caseAfter all these years on the shelf its liable to be no good antmore
Cool ,,it maybe able to be rejuvinated as long as the plates aresnt shorting out cellsNo it's not - it's been replaced but i have the original case![]()
Well there ya go! Will it be in mopar label?Just order one. Original 2004 part number is 56028452AA; the p/n evolved to -AC by 2005 and is now 56028452AD. Part number searches show both -AC and -AD available.
I would assume so since it would be ordered from Mopar under that part number. That being said, it likely will be a more modern label, like so:Well there ya go! Will it be in mopar label?
I've heard there are a few companies that produce the batteries anyways so why pay the extra lolI would assume so since it would be ordered from Mopar under that part number. That being said, it likely will be a more modern label, like so:
Also ordering a battery from OEM allows you to pay probably twice what you would for any other brand of the same spec.
They must get hot hahahaha - interstate works good for me but we use batterymart and they work good too all same stuffSince ive been in FL hell i have bought more batteries from my vehicles than the rest of the places Ive lived my entire life .. brand makes no difference .. WTH !
Been wondering if maybe the battery temp sensor maybe causing the batteries to get eatenThey must get hot hahahaha - interstate works good for me but we use batterymart and they work good too all same stuff
Maybe if it's malfunctioning. The reason for its existence is to fine tune charging relative to battery temp, so if it's giving false readings there may be an issue, but honestly as long as it charges at 13.6-14.6 volts whilst running it doesn't matter.Been wondering if maybe the battery temp sensor maybe causing the batteries to get eaten
Ill need to check the charging and see what it shows on mine ..Maybe if it's malfunctioning. The reason for its existence is to fine tune charging relative to battery temp, so if it's giving false readings there may be an issue, but honestly as long as it charges at 13.6-14.6 volts whilst running it doesn't matter.
Get a Ford! HahahahaIve had 3 codes on my Dakota , 0051 , 1492 and 0432 for a long time... One is the battery temp sensor the others are 02 sensor or catalytic converter system codes ..
No chance getting a Found On Road Dead or Mile Marker Mustang..Get a Ford! Hahahaha
