- Joined
- Feb 26, 2008
- Messages
- 9,775
- Reaction score
- 5
I think you should do a 2 stage, 500 shot of NOS
Why you scared of your bro beating you? Whats he up to?
A JMB Procharger kit-
JMB Performance & Powdercoat, LLC
http://www.jmbperformance.com/photos/DSC00506.JPG
or a Paxton...
AND you can keep that nice looking Intake Manifold.
My opinion..
Ronnie
For sure the Procharger.
I have watched all the results over the years on these sites and the Procharger is the best bang for the buck. Good parts right off the bat that can handle much more power at a later date once you have built the motor.
Justin's quality of each component is second to none and he will customize your kit for what you want to achieve.
2005 SRT-10 Ram F1C Procharger - first fire up - YouTube
Supercharged Dodge Ram SRT-10 on dyno at PSI - YouTube
it sure does !!!!
you forgot the other option, chris...
sell it and buy an L... will be SOOOOO much faster
If I was going to invest in serious power mods, I would be looking at n/a stuff. Heads and intake yield better numbers than some s/c builds, without the hassle, and with less cost.
-Chris
it sure does !!!!
What does that set up cost?
A built motor is going to be around $12k
Paxton is $6.5K for the tuner kit. In addition you will need SCT tuner, bigger injectors, 2 bar map sensor, (and dual in-tank fuel pumps not necessary but recommended)
Roe is $7.3k for the kit. In addition you will need SCT tuner.
Procharger is $6.5k for the base kit. In addition you will need JMB electric fan assembly $700, SCT tuner, bigger injectors, 2 bar map sensor, (and dual in-tank fuel pumps not necessary but recommended)
Options $2.6k for the front mount intercooler
If money is no object Procharger, if your on a budget Paxton. Of course you will need to add funds for tuning the monster once it is done.
Tell ya what chris lets swap Truck for Truck
:drool:LMAO, You would get the losing end of that deal.
Midnight Runner said::drool:LMAO, You would get the losing end of that deal.
1BADTRK said:I'd Take the Lost
I'd Take the Lost
