Srt10ram
- Joined
- Dec 4, 2008
- Messages
- 126
- Reaction score
- 0
What's up everybody. Yesterday I encountered a ticking noise coming from, what I think was the DS top part of the motor. I started early in the morning moved it down the driveway and no sound was there. Late in the afternoon I started it to take it for a drive, and this sound was there. It was loud enough to here inside the cab, so I got out and started looking around with it still idling. I found it was coming from the Driver-side half of the motor, probably in the valve-train. It almost sounded like a stuck valve. This might've been a dumb decision, but I rev'ed it up to about 2-2.5k rpm and the noise just disappeared. Let it idle awhile all the gauges looked fine (Oil Temp, A/F, Oil Press.), it was idling fine, and then took it out for a spin. Drove completely normal and no noises. The oil was changed less than 800 miles ago.
The truck has 16k miles and hasn't had a problem, besides 2yrs. ago when I discovered a bolt in the oil pan @ 4500 miles. Long story short, I brought it in, and the mechanic(s) at dodge assumed it backed out from under-tightening. They ended up replacing the valve spring girdle on the driver side. Since that, nothing has gone wrong or any weird noises have popped up. Scared the shit out of me when I heard the noise, got me thinking maybe I should get another extended warranty cause the one I had expired last year.
Has anyone had this happen or heard of this happening? Really clueless right now...
If this sounds comes back I'll be sure to get a video and post it here.
