Hotchkis Sway Bars - Front and Rear
HaroldD
Phoenix, AZ
I've had the Hotchkis set of bars in my garage for over a year :dontknow: , and I finally got around to doing something with them yesterday.
The front is a no-brainer. Unbolt the frame mounts, unbolt the top bolt of the links, remove. Install new poly top bushings on the end link, install new poly frame mounts and you're set.
Interesting note on the front - you go from a 25 lb stocker to a 16 lb Hotchkis since it's hollow. But, since it's 0.25" larger diameter, you still get great performance out of it. I did just the front first, and over a few hours drive time, noticed that it seems smoother up front and not quite as jittery over potholes.:congrats: Not much to take pics of here - it's just a bigger sway bar in the stock configuration.
Off to the rear. Hotchkis does not officially list our trucks, but I spent about 30 min speaking with a tech there (over a year ago) and we concluded that if there was any interference, it would be on the shock mounts where the bar mounts bolt up.
Well, we were right, but it was a pretty easy fix. You can't use the existing holes on the bottom of the shock mounts - you need to drill some new ones offset F&R by ~1" to get the bar to line up. Without that, the bar is not parallel to the axle. After that, piece of cake.
I know, :needpics: so here's a few. These were taken with the rear axle fully drooped. The rear of the bar tucks up just underneath the drain plug in the rear diff cover at ride height on my truck.
Was it worth it? Certainly. No ill affects and lane changes feel a lot more solid now. Truck seems to stick better and is even more predictable. Now, I can take more advantage of the KDWs by keeping them planted! :rock:
One note - if you go to their site, the pic is generic. You do not get new end links for the front, just new top bushings. Seems fine for stock ride height like mine - they do sell other kits for lifted and dropped.
thanks for the write up. there's another way for us to knock a few more pounds off the front of the truck:rock: and better handling too
Nice write up. :rock:
How long did the whole install take you?
Do remember how much the kit was?
Other than drilling the holes in the lower shock mounts, was the rest of the rear bar bolt on? Where did the end links bolt to?
Nice!! Hotchkis made some really good stuff!!! i had a TVS kit put on my old Rumble bee and it handled great! those sway bars make the truck feels like a sports car....i dont know why QC's didnt come with them :dontknow: or atleast the rear one...
Not long - I did other things like the QA-1s and rear brakes at the same time, so it's hard to say. I'm also one to take my time; I use a torque wrench on every critical bolt. :rock: :rock:
I purchased it direct; I seem to remember $525, but it was a year before I did the writeup, so times have changed and that was cases of Quervo ago... :dontknow: :dontknow: :dontknow:
Bumping this old thread!
Have anyone tried these recently or still using them? Or maybe another challenger has appeared!? ^^
I had a BellTech rear stabilizer bar on mine that I don't need now that I convertered to a ladder bar setup. Powdercoated red and all the mounting hardware minus the nutserts.
I know this is an old thread but did you order the ones for a Ram 1500, since they don't have the SRT 10 listed on the site?
Yes, the 1500s worked with the mods shown. Note that mine is a QC.
