Leaking steering rack.....again
yellowfever#154
Lacombe, Alberta
Anyone dealt with leaking high pressure lines on the steering rack before? I've replaced the rack once because of the same thing and here we go again. I've tried to find seal kits that include the Teflon rings needed for these lines but they don't come with. Any advice?
I had the same issue a couple of years ago. I did a lot of searching and found this to work: russell fittings. Order four of them and get some braided lines made and you will be good.
That's the answer I needed, thank you! I will look into these in the morning. I removed the rack tonight and was about to have my welder braze the lines in place tomorrow, I might hold off now and try these first.
