Random lights
is it possible for the sensor to be going bad and as a result causes the wheel to stick. I had it on the lift and could not turn the front left. flushed and replaced fluid then drove it seemed ok then the light came on randomly again. sometimes the airbag light and sometimes the abs brake light. i got a caliper rebuild kit but now i question the sensor.
which is the best bearing for these truck the Masterpro bearings or the National bearing just got the lights and think about going ahead replacing all four plus the axle bearing i just hit 103K miles so i figure it's time to do some deep maintenance.
