Ironhead special . made my own kit .Its a 2 /3 .With 304/45/22 nittos I got a set of 3/4 ton springs from an 05 and bobbed them and machined my own rear drop blocks at work . Bought a monster set of u-bolts for rear axel off ebay .Then got some smaller bump stops off ebay too. Aluminum from work was free so was me milling down the block from a 4in piece .lol Probably cost me $100 bucks .But not for the faint of heart though .
Custom set up. Mmw uca mounts, x metal springs, DJm lower control arms, Poly bushings, poly bump stops, Hotichkis sway bar, shorted sway bar links, bump steer kit, qa1 shocks Rear: jtsvp rear 4" blocks, custom c notch, custom leaf spring pack, poly leaf spring bushings, jmb traction pack clamps, Hotichkis rear sway bar with shortened links, qa1 shocks If your not happy with the ride change all the rubber bushings to poly and get some upgraded shocks
