Throwing a code. P3231
JustinRamSRT10
Long Island, NY
Hello again guys. Just wondering if anybody has thrown this code before P3231. Check engine light came on after sitting overnight. If anyone knows what it is or even has a fix, it would be appreciated. Thanks.
Thanks for the response and great list. Unfortunately P3231 isn't on there though.
According to the source I looked at :
Trouble Code: P3231
Control Module Monitoring Error Response Plausibility
Possible Causes:
Battery terminal corrosion, loose battery connection, or faulty
Connection to the DME interrupted, or the circuit has been opened
Reprogramming error has occurred
and needs replacement.
Voltage supply for Engine Control Module (DME) is faulty
good luck!
--CC
