Dyno my truck...
Discussion in 'Dyno Stuff' started by Sammy11, Aug 13, 2015.
  1. Sammy11
    Sammy11 Active Member Supporting Member
    1,677
    Sep 8, 2008
    Belgium
    What is the best way on a dyno for the most accurate test ?
    I think , for automatic , in 2 and then go ?
    or is it another way to do...?
  2. Arska2
    Arska2 EU Moderator
    1,253
    5
    May 5, 2012
    Hamburg, Germany
    3rd gear is 1:1
    It has to be strapped down and if possible dont do it on a too hot / humid day.
    They will recalculate the values but still a good climate is the best way to get decent results.
  3. JMB Justin
    JMB Justin Active Member Preferred Vendor
    2,649
    Sep 19, 2006
    Hillsboro MO
    Remove the kickdown cable from the TB, put in tow haul in 3rd gear, make a pull from 2000-2500 or so to 6000.
  4. NukeGM/Ford
    NukeGM/Ford Active Member
    1,804
    11
    Oct 4, 2014
    North Las Vegas, NV
    Same gear 4 sticks? ?
  5. trussman
    trussman Active Member
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    4th is 1:1 on manual
    Sent from my SPH-L520 using Tapatalk
  6. NukeGM/Ford
    1,804
    11
    Oct 4, 2014
    North Las Vegas, NV
    Thanks
  7. LeadFt
    LeadFt Full Access Member
    67
    May 23, 2012
    Justin knows his stuff
  8. Sammy11
    1,677
    Sep 8, 2008
    Belgium
    would it shift further to 4th gear ?
  9. Arska2
    Arska2 EU Moderator
    1,253
    5
    May 5, 2012
    Hamburg, Germany
    If you press tow/hal button it will not shift to 4
    Have fun
    Arne
