Soapy00
Nearly overheated the truck when i got home and popped the hood and found the radiator hose came off the top. Should I replace the clamp? The hose? It doesn't look damaged nor does the clamp...
I'd replace it all to be safe, they are very cheap.
So i just replaced the radiator cap (which was warped) and the hose / clamp, i'll keep an eye on it to see if the tstat needs to be replaced. Thanks guys!
Ugh, so the Porsche dealer (who I bought it through), can't figure out what's going on, they say there's bubbling in the radiator when it runs, I now have to have it towed to the Dodge dealer down the street to get a diagnostic run on it to figure it out. Hopefully whatever's wrong is covered by warranty and the engine isn't cooked...
Sent from my Nexus 6 using Tapatalk
If the Dodge dealer does not have a Viper certified mechanic then I would run. I have been to both and I believe there is a huge difference. One dealer said he did not have a factory certified Viper mechanic and refused to work on my truck. I also realize the many of the guy here are everybit as good as a factory trained Viper mechanic but by and large the dealerships are not that specialized.
Also is must be understood that most of us here should be "certified" but that has nothing to do with the SRT-10 trucks----frontal lobe issues. :burnout:
I dont understand this "Viper Tech" certified stuff. Because the block has two extra holes in it they need to be certified? Maybe they just make sure that the "Viper Tech" isnt a complete idiot and actually has a basic understanding of being a technician?
