BBK or JTSVP TB?
Discussion in 'Performance Mods' started by Angelo621, Jan 3, 2019.
  1. Apex
    Apex New Member
    10
    8
    Dec 21, 2019
    Detroit
  2. rottenronnie
    rottenronnie Well-Known Member Supporting Member
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    Any of the throttle bodies I've tried provide better throttle response (bigger openings), so more airflow for a given throttle position compared to stock. 8-10 HP on the dyno. We spent several hours back-to-backing on the dyno so the tests were valid.
  3. rottenronnie
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    Some guys report 11-13 HORSEPOWER with a throttle body swap.
    A gain is a gain, regardless.
    The change in throttle response made it worthwhile for me.
    MERRY CHRISTMAS TO ALL
  4. rottenronnie
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    Between that and an underdrive crank oully you can pickup 20 horsepower (easily).
    Pulley size is everything. When I was selling them, it worked well and not until every single accessory was turned on at idle, was a slight drop in charging noted. That is where we stopped going smaller in size.
    I'm not sure who is selling them anymore but that is another easy power mod (provided it isn't too small) .
  5. rottenronnie
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    Oully= pulley.
  6. Jumpingjoe628
    Jumpingjoe628 Full Access Member
    104
    40
    Aug 11, 2018
    Charleston, SC
    What size (diameter) worked when you were selling them?
  7. rottenronnie
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    I will look tomorrow and post .
    Jumpingjoe628 likes this.
  8. rottenronnie
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    We haven't made them for 10 years and I don't remember.
  9. rottenronnie
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    5"
  10. GSJake
    GSJake Active Member
    207
    106
    Feb 13, 2018
    Spoke to Dan the fast man (great guy on the phone). He is booked up until early February with hemi stuff and has no cores atm.
    He said if you can afford the down time you can ship yours and he will coordinate it so it will be done in a day and back out to you.
    I will be re-visiting this in spring and keep an eye out for a used TB for a good price so I can swap them out.
  11. AMS3
    AMS3 Well-Known Member
    1,068
    768
    Aug 8, 2019
    Savannah Ga
    I'm thinking of doing the same as you. I saw a few on Ebay just a few days ago. Don't remember the asking price though.
  12. VIPR PWR
    VIPR PWR Well-Known Member Supporting Member
    7,585
    2,942
    Jun 12, 2007
    FL
    All I have seen on eBay , mostly BBK throttlebodies are 399.00 with a few over 400$
  13. AMS3
    1,068
    768
    Aug 8, 2019
    Savannah Ga
  14. VIPR PWR
    7,585
    2,942
    Jun 12, 2007
    FL
  15. AMS3
    1,068
    768
    Aug 8, 2019
    Savannah Ga
    Good Point. I think I'll go with the JTSVP TB. It comes as Plug and Play, right? Or are there other parts needed to buy?
  16. VIPR PWR
    7,585
    2,942
    Jun 12, 2007
    FL
    Not sure how it comes ... I bought the BBK years ago before any others were made ... If I was to get another one then I would call Tony at jtsvp and ask about it ... maybe someone else can answer that question on here ....
    AMS3 likes this.
  17. Jumpingjoe628
    104
    40
    Aug 11, 2018
    Charleston, SC
  18. rottenronnie
    4,177
    2,151
    Jul 4, 2006
    Calgary, Alberta
    BBK comes complete (or they used to years ago).
    Others require you to remove the throttle blades from your original unit and install into the new one.
    They all provide better throttle response and more wot power.
    I never tried a single blade. If you search old threads (this forum) there are comments about them.
  19. CaptnCrash
    CaptnCrash Full Access Member
    217
    38
    Jul 1, 2014
    I put my XMetal single blade back on after I got tired of the BBK sticking and the additional return spring I had to add to stop that stuff. Now my cruise control works again.
    XMetal single blade makes more seat-of-the-pants power and it's got way, way better response.
    AMS3 likes this.
