JTSVP Throttle Body Install
Discussion in 'General Discussion' started by Gill, Aug 12, 2020.
Car Parts
  1. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Good afternoon, just acquired Tony's TB from a user on here. Thing is new, I do see instructions that came with it. Just a tad confusing, I consider myself a decent wrench head but with the last couple run ins on this motor, I'd take advice prior to anything (spark plugs driver side made me a believer).
    Anyone who has it, any advice as to installing it? Looking to complete this weekend
    Thank you!!
  2. oldcolt
    oldcolt Striker Heads and Cam Supporting Member
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    Is it fully assembled, or do you have to install your TB blades in it? If it's ready to go, it only takes a few minutes, just make sure you install the TPS correctly.
    Kiwi SRT10 and Srt10650 like this.
  3. Srt10650
    Srt10650 Full Access Member
    360
    305
    Sep 30, 2016
    Like OldColt said, if it’s plug and play it should only be the 4 bolts from the intake manifold and the 2 that hold the tps sensor. If not you have to disassemble your stock one and remove the blades to get to center shaft. Then remove the shaft, install the shaft and new blades one the new one along with the tps sensor. Re install the 4 bolts, connect the tps sensor and You should be good.
    Kiwi SRT10 likes this.
  4. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Not assembled, have to take apart the stock one
  5. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Any special things to watch out for?
  6. GSJake
    GSJake Active Member
    207
    106
    Feb 13, 2018
    When putting back on the TPS ensure its not reversed on the throttle shaft.. this will peg the throttle open when you first start it up... ask how i know. :rolleyes:
  7. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    Make sure everything moves freely before you install it, the blades may hang up.
  8. rottenronnie
    rottenronnie Well-Known Member Supporting Member
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Good morning Gil.
    Hopefully your new TB is for an automatic transmission (has the proper bracket).
    There is a small rubber line that comes off the intake behind the TB that points straight down. Make sure that is connected before the new TB goes on. Also check the condition of the gasket between the TB and mouth of the intake manifold.
    Work the throttle a few times prior to fire up to make sure operation is free, without binding).
    Easy job.
    As you look in horror at the oily shellac inside the throttle body and intake, you may want to consider a catch can to prevent that. If you have a catch can disregard.
    Have fun
  9. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Would you have a photo of the TPS for reference?
  10. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Copy that
  11. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Hello Ronnie! I didn't think the TB's would be different. I purchased this TB from a user that had a manual, hopefully its proper.
    I had changed the TB gasket about a month ago while changing valve cover gaskets. I have yet to install a catch can, any suggestions?
  12. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Hi Gil:
    Maybe they all come setup for the kickdown cable; I don't know any thing about the one you have.
    Have a look at yours and see if the linkage setup looks exactly the same as the one on your truck. If it does, you are good to go.
    I like the catch cans that are completely sealed; in other words they don't have a little air filter on top.
    You kind of get what you pay for with catch cans.
    I was the beta tester for RX Monster catch cans on the SRT-10 but I don't know if these are still sold.
  13. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    It does look the same, should be a solid fit
    I have one that I bought many years back, its sealed. Will give that a go, just need to find a place for it around the engine bay
  14. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I mounted mine "inside" the spare battery tray.
  15. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    I've taken that out to place the CAI. I guess I can run the catch can through that
  16. GSJake
    207
    106
    Feb 13, 2018
    If you have not installed it yet.. this is a good reference for any of the aftermarket TB's.
    Srt10650 likes this.
  17. Srt10650
    360
    305
    Sep 30, 2016
  18. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Alright, so I've hit a bit of a bump. Removing TB was a cake job but the blades a different story. I started to loosen the screws and the head broke off. Any suggestions on removing the broken bolt?
  19. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    How well do you know your dentist?
    You may have to buy him a bit or 2 but they aren't expensive.
    It needs to be carefully drilled out.
  20. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Luckily have one across the street :D
    Were these put on with loctite OEM?
