hood question
Discussion in 'General Discussion' started by CYS, Feb 17, 2021.
Car Parts
  1. CYS
    CYS New Member
    24
    4
    Jan 8, 2021
    Las Vegas, NV
    So i noticed there is a plastic piece on the inside of the hood but is only on one side (see image), my question is should there be one on another side? If so, does anyone what part # it is? Thanks.
    [​IMG]
  2. rottenronnie
    rottenronnie Well-Known Member Supporting Member
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    The other side should be open for engine air.
    Kiwi SRT10 likes this.
  3. TrailMix
    TrailMix Full Access Member
    80
    7
    Feb 3, 2011
    Mississippi
    Mine came with one on each side
  4. CYS
    CYS New Member
    24
    4
    Jan 8, 2021
    Las Vegas, NV
    interesting, anyone the part # or where i might get one? I've search all over but no luck locating it. Thanks.
  5. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    I have one I took off of mine when I changed out the grill inserts, let me know if you'd like to purchase
  6. CYS
    CYS New Member
    24
    4
    Jan 8, 2021
    Las Vegas, NV
    is it in good condition? How much are you asking?
  7. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    See attached, pretty good shape. Make me an offer
  8. CYS
    CYS New Member
    24
    4
    Jan 8, 2021
    Las Vegas, NV
    is the 05 the same as 06, because looking at the one you have for the driver side it seems like it looks different that what i have on mine.
  9. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Looking at photos online they look very similar, but its up to you
  10. CYS
    CYS New Member
    24
    4
    Jan 8, 2021
    Las Vegas, NV
    let me double check my hood and make sure it fits, is in the shop now so i will get back to you monday when i get it back. Thanks.
  11. AMS3
    AMS3 Well-Known Member
    1,066
    766
    Aug 8, 2019
    Savannah Ga
    What's the purpose of the blank outs, to direct the airflow into the engine comp better?
  12. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    Yes.
    The passenger side has an opening/redirect "scoop" that directs outside air into the Airbox.
    AMS3 likes this.
  13. CYS
    CYS New Member
    24
    4
    Jan 8, 2021
    Las Vegas, NV
    Could it be possible the 05 have two and the 06 have only one?
  14. SRT10FOUR
    SRT10FOUR Member
    66
    35
    Apr 6, 2020
    I have an 05 with both the right and left side. Should I be removing both of them? Or are there drawbacks to removing both of them?
  15. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    The panels are there for aerodynamics and primarily cooling. The passenger side directs air into the air box for the engine.
    AMS3 likes this.
  16. oldcolt
    oldcolt Striker Heads and Cam Supporting Member
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    As Ronnie mentioned, the drivers side is there to prevent lift at high speed and direct air to the radiator. The passenger side directs air to the filter intake. The 04 and 05 have different grill shapes than the 06. I’m not sure if those pieces interchange.
    GSJake and AMS3 like this.
  17. AMS3
    1,066
    766
    Aug 8, 2019
    Savannah Ga
    Hmm, I need to look at my truck, not sure if I have them.
  18. CYS
    CYS New Member
    24
    4
    Jan 8, 2021
    Las Vegas, NV
    so i guess that might explain why my passenger side is missing, the person before installed a mopar intake with the cone air filter. Perhaps that part was removed to force more air into the intake? Just a thought.
    Anyone know what part # they are? Would like to see if the 05 and 06 are the same or not
  19. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    A dealer might be able to help you.
  20. SRT10FOUR
    SRT10FOUR Member
    66
    35
    Apr 6, 2020
    This is the best I can do. I just took mine off to clean and maybe paint them since they are discolored very badly. These are from a 2005 QC.
