2 issues driving me crazy.
Discussion in 'General Discussion' started by mr.goat, Nov 15, 2013.
Car Parts
  1. mr.goat
    mr.goat Full Access Member
    114
    Apr 20, 2013
    Mexia, TX
    First. I bought new rear speakers. How do I remove the sub? It seems locked in place.
    Next. Is there a magic blessing that can be bestowed upon the truck to make it stop self locking. This drives me nuts as I'm the only one that rides in her and I put things on the passenger floor all the time. I constantly forget to unlock the truck before running around. Just to go all the way back around and unlock it. They drive me Nuts!
  2. caveman
    caveman Active Member Supporting Member
    7,491
    5
    Jul 20, 2011
    Western Colorado
    I'm told that a good whack with a 10 pound sledge loosens up the sub. Makes reinstallation difficult though. :D
    As for the auto locking, I hate it too and hope someone has a better suggestion than I have regarding sub removal.
  3. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    Ok guys what ya do is cycle key 4 times to on(no start) then to off. You'll end in off position. Hit door lock button on door panel and you'll hear a chime confirming deactivation. Gotta think about sub, its been awhile on that. :rock:
    Thought it was just removing screen, then screws holding speaker in. It may have had a sealing tape on mounting edge that's sticking?
  4. rare03srt10
    rare03srt10 Full Access Member
    2,941
    Feb 3, 2011
    Fountain Valley, CA
    Venomous1 is correct but I also want to say there is a option on the overhead console to change the beep tone, auto door lock/unlock, lock/unlock lights flash with key fob, ect ect
  5. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    How do you get to options through overhead? That I never heard but would like to see :rock:
  6. rare03srt10
    2,941
    Feb 3, 2011
    Fountain Valley, CA
    Well i dont have my truck anymore so i cant go run outside and check lol but Ill swing by my parents house and look at my dads dodge see if its the same or not. Im almost positive thats how i did mine when i had it. Im 110% sure once i was in some sort of options i was able to change the volume of the "beep" when you pressed the lock button from the fob, i was able to change the settings for the lights flashing when you pressed lock/unlock and the auto door lock. Just gotta double check how i got to those options lol
  7. TheMoparConnection
    TheMoparConnection Full Access Member
    3,978
    Jun 9, 2006
    Ram Trucks 03 and prior with the Laramie package had the option on the overheads. 04 and up did not come with that option.
    I have it on mine because I took it out of a 02. You can program key fobs, change you settings for door locks, horn honking. Service intervals in mileage, its pretty neat
  8. caveman
    7,491
    5
    Jul 20, 2011
    Western Colorado
    Very cool!
  9. caveman
    7,491
    5
    Jul 20, 2011
    Western Colorado
    Thanks, Scott!
  10. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    You try it first? It's been awhile. I'll try mine in a bit to make sure.;)
  11. rare03srt10
    2,941
    Feb 3, 2011
    Fountain Valley, CA
    That makes sence then because my truck was a 03 with a 05 SRT-10 powertrain. I even changed the dash wiring to 05 SRT-10 but i guess my overhead still let me do it since it was from 03
  12. caveman
    7,491
    5
    Jul 20, 2011
    Western Colorado
    Just tried it and it didn't work.
  13. mr.goat
    114
    Apr 20, 2013
    Mexia, TX
    Ok thanks Scott. As always helpful as hell. Sub came right out after I pulled the two screws holding it to the bracket. Haha so obvious it was tricky
  14. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    Try again bro, it worked on mine. Cycle key from off to on 4 times and leave off on 4th. Then hit door lock switch to lock. Should chime. Do process again to enable. Make sure door is shut while doing this.
  15. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    Glad to help sir :burnout:
  16. TheMoparConnection
    3,978
    Jun 9, 2006
    If you have a quad cab you can set it to unlock all doors when you open your drivers door. That way you can keep the self locking doors. I can look up the procedure for that if you'd like or you can get it out of the owners manual.
  17. ViperCLKGTR
    ViperCLKGTR New Member
    1,088
    Jun 3, 2012
    I would like to know how that works...
  18. Ironhead
    Ironhead Full Access Member
    11,306
    Jan 14, 2008
    h-town
    Its in manual ,its a cycling of the key on off on off lalalalaa
