2004 manual no start
Ramviper69
I have manual 2004. When I'm trying to start it I can feel starter turn. 2nd try it would just click. Replaced starter, and new batt. Same with new starter and batt click barely turning the engine. I can feel engine turning like half way. Also is this the starter relay next to the parking break (pics attached)? Any feedback would be appreciated. 28k miles. Also how do you remove the relay?
Check all connections , be sure no corrosion ( especially on the battery terminal connections) , make sure all grounds are tight and clean , wiring is all good … be sure the battery is charged and good , same with the starter and solenoid connections and wires , just because it’s new doesn’t mean it’s good. Those I would be the first things I would do to verify things ..
According to AI : I have a 2005 QC and I didn’t see a starter relay list in my panel !
The starter relay is in the under-hood Integrated Power Module (fuse/relay box), beside the battery. Look for the diagram on the underside of the cover; it identifies the Starter Motor Relay. On the 2004 layout, it’s relay position 72. startmycar.com
Turn the ignition off before removing or swapping a relay, and use only an identical relay for a test.
Why AI sucks lol :
For the 2004 Ram SRT-10, the starter relay is under the driver-side dashboard, beside the steering column and parking-brake switch—the same location reported for the 2005 SRT-10. It is not the relay in the under-hood fuse box; the “Starter Motor Relay” position shown there is marked for vehicles other than the SRT. vtcoa.com
I need to correct my earlier answer: saying it was in the under-hood box at position 72 was not reliable for the SRT-10.
Here’s an old thread on here !
Replaced starter, same just click
Load test the battery in case it has a bad cell
if possible you can try using a jumper lead across the starter solenoid and see if it kicks the engine over …
I just need to figure out if these two under steering wheel next to the parking break is the relay. No markings on them.
From the above posts it states the relay is in that place for the 10’s.
Your pic appears to show 2 relays … relays are like $5 .. replace them both but make sure the types match … other than that compare the relays in the fuse box under the hood for the same type by the brake pedal and use one to test the 2 .. other than that I’m not really sure what your purpose of asking is based on the original post ..
Calling @rottenronnie , @Kiwi SRT10 , @Wifey ( link to owners manual! ) , @HemiLonestar
I'm questioning that these 2 relay next to the parking break have no labels on them like the typical relay.
And that's why I put the manuals on the site lol.
We thank you for that !
I was skimming through the start relay section and didn’t find the info that the starter relay is under the dash and stated it is in the under hood fuse box .. I checked my truck and there is no starter relay in the under hood fuse box .. I have found other info and a thread on here that the relay for the 10’s is by the emergency brake pedal and I think begin the kick panel which I’m not going to take off to check ..
the op should just pull the ones he’s seeing and as cheap as they are replace them Marked or not .. The ones in the pics above have a number for the relay …
If it is engaging the relay is working. My truck has to have the battery disconnected or it won't start after 3 weeks. These trucks are bad for it. t
There are so many parasitic losses between computer, entertainment centre and burglar alarm. Have a solar trickle charger to keep topped up.
Remove leads and clean terminals.
Clean earth strap to body and engine contacts.
Charge battery
Try again.
Charge battery
Try again.
Agreed
