2006 srt10 ram neutral safety switch
06qcsrt10
Member
Hi , I’m looking to bypass the neutral safety switch on my 2006 srt10 quad cab since I went to a T56. I cannot find anywhere online which wires I need to connect. I’ve read diagrams but nothing clear
Maybe Tony @ JTSVP could shed some light since he's done 06 conversions .. might be worth a call to them
Member @6speedquadcab mentioned he took his there
Pulled this up asking AI ,,, see if this helps …
Yeah, for your 2006 Dodge Ram SRT-10—factory auto was the 4-speed auto (no manual option stock), so if you’re swapping to manual, you’re basically ditching the old neutral safety setup.
The neutral safety switch (from the auto trans) plugs into a 6-pin connector on the trans case—it’s got wires like:
• Pin 1: fused ignition (run) output, often white or gray.
• Pin 6: park/neutral sense (purple or tan/white—grounds or signals when in P/N).
• Others handle backup lights, voltage supply.
After swap? Just unplug that whole harness from the trans—tape it up, tuck it away. No need to rewire anything; the starter relay gets power straight from the ignition/start circuit now. (See that wiring snippet—manuals ground the relay differently, no neutral interrupt.)
The clutch safety switch (your new one) is way simpler: two-wire job, mounted right on the clutch master cylinder plunger under the dash. From SRT-10 guys:
• Two black wires go to a connector near the pedal.
• But power comes in on yellow/orange (from start button/ignition) and out on pink/orange to the starter relay.
Push clutch—closes the loop, cranks. No push? No start. If it fails, jump the two colored wires (yellow/orange + pink/orange) or the blacks—bam, bypass.
Here’s what it looks like under there—clutch switch circled in green plug:IMG_3288.pngIMG_3289.png
Here’s what it looks like under there—clutch switch circled in green plug:View attachment 69693View attachment 69694
Dang AI is going to take over! Run Forrest Run!!
It surprised me on the answer and has taken sources from 42 checkable sources on the internet .. even Forrest can’t run that fast ..
