48RE issue
Discussion in 'General Discussion' started by SmokeSRT, May 21, 2019.
Car Parts
  1. SmokeSRT
    SmokeSRT New Member
    6
    Sep 4, 2018
    I have a 05 Quad cab and I currently lost reverse gear so I decided to drive it to the parts store anyway and noticed it wouldn’t shift into 3rd gear also; besides the Governor solenoid and pressure transducer upgrade, what could be the problem? Thanks for any help!!!
  2. rottenronnie
    2,828
    177
    Jul 4, 2006
    Calgary, Alberta
    Do you have 1st gear (the shift lever is pulled into "1") ??
  3. rottenronnie
    2,828
    177
    Jul 4, 2006
    Calgary, Alberta
    When you pull the lever into "1", the valve body applies pressure to the Low/Reverse Band.
    In other words, the BAND shares low and Reverse. If you get nor forward movement in "1", you have a band issue which is not uncommon.
    This is different than when it is in D for Drive as it is going through a different circuit.
    It sounds like you need a trans overhaul.
    I don't know what your power level is and you may need some upgrades if it is higher than stock.
    The 48RE can have (often does have) an issue with particles from band, clutch material and other debris.
    For such a simple transmission, they can be quite a challenge to rebuild properly so it's necessary to have it rebuilt by someone who knows them well.
    TrailMix and THEWELSHM like this.
  4. SmokeSRT
    SmokeSRT New Member
    6
    Sep 4, 2018
    Yes I have 1st gear.
  5. SmokeSRT
    SmokeSRT New Member
    6
    Sep 4, 2018
    I get forward movement in 1 and drive. It just doesn't shift into 3rd when cruising and of course no reverse. I had a overhaul about 18 months ago, so I guess you're saying he might not of been my best choice. I am currently stock no bells and whistles.
  6. rottenronnie
    2,828
    177
    Jul 4, 2006
    Calgary, Alberta
    Based on the above info, your transmission will require another tear down and overhaul.
    I can't really comment on the specific failure as it could have been a defective part(s) and not the fault of the installer. (?)
    My own 48RE would jam itself in 2 gears at once and create a "dynamic lift kit" where the whole truck would rise straight up and move ahead like it had a 383 for an engine.
    Several guys I talked to said that wasn't possible but it managed to spin the planetary backwards and rip all of the locating pins off the housing (also not possible). So, apparently it was possible as evidenced by the facts. Odd things CAN go wrong = "Shit Happens".
    I was just talking to my trans guy and he said your unit may have burned the direct clutches out as 3rd and Reverse use them.
    The fluid will smell (and look) burnt.
    Where are you located?
  7. shorty
    shorty Full Access Member
    2,051
    26
    Sep 1, 2012
    Emory, Texas
    My rebuild has just over 108,000 miles. Still perfect.
  8. rottenronnie
    2,828
    177
    Jul 4, 2006
    Calgary, Alberta
    Any progress?
  9. SmokeSRT
    SmokeSRT New Member
    6
    Sep 4, 2018
    West Virginia
  10. SmokeSRT
    SmokeSRT New Member
    6
    Sep 4, 2018
    No progress as of yet. Will take it to local shop next month. Thanks for the info.
  11. rottenronnie
    2,828
    177
    Jul 4, 2006
    Calgary, Alberta
    Okay, well good luck with it.
    I'm curious to know what they find.
  12. Bad Plum
    Bad Plum Full Access Member
    114
    Sep 28, 2015
    I have 48RE for sale with 38k miles on it.
  13. rottenronnie
    2,828
    177
    Jul 4, 2006
    Calgary, Alberta
    Is it stock or modified?
    Price?
    Thanks
  14. rottenronnie
    2,828
    177
    Jul 4, 2006
    Calgary, Alberta
    I still haven't figured out how to edit a post.
    Is it working properly or does it need rebuilding?
