My A/C all of sudden started smelling like a cattle barn. If I turn it to heat and turn the A/C button off it is fine. A google search indicates that 2005 Rams did not have a cabin filter, this has usually been the culprit for other cars that started smelling weird. Any ideas what could be causing in on our SRT10s? Thanks
make sure the a/c drain is not blocked. poke a cable tie into the drain to free any of the built up sludge. the drain is located at the bottom of the HVAC and penetrates the floor to the outside of the vehicle.
I think I found the drain tube, it is just sticking out of the fire wall about 1 inch, just behind the bottom of the AC accumulator. I put a hose on it and can freely blow through it, and then hooked the shop vac up to it, and didn't suck anything out of it either, so its clear. I did let the AC blow on HI, which I hardly ever have it on that hard, and it seems to have went away after blowing on hi a few mins.
Yes, pass side, just slightly to the right of the AC accumulator at the bottom, can't miss it, a tube about 1 to 1.5 inches long sticking straight out from the firewall, about 1/2 inch in diameter.
Found it! I can’t get a shop vac hose to mine, but do we know how deep it is?? would a 6-8” pipe cleaning brush be long enough to clear any possible debris?
I first stuck a piece of solid copper wire up the tube, went about 6 inches in, didn't clear anything out, don't think there was anything to clear out in mine, but then I just put a piece of heater hose over the tube and I could freely blow air through it so again, figured it was clear, then just put the shop vac up to the heater hose that I had connected to it just to make sure.
If it doesn't smell the same on Recirc ....Check your air intake, make sure there is nothing dead in there, you may get a surprise.
