So far I've found 2 of possibly 3 leaks.
This is one the '04 RC I purchased from "Bikertat".
It looks like one of them is what is causing the overheating, (big bubbles & burping in the radiator) looks like a blown head gasket.
The red fluid was coming from a crack in the tubing lines on the rack&pinion. Unfortunately buy the time I found it, the driver side seal must have failed, because fluid started pouring out of the boot as fast as I was putting it in.
But, Mike said the new rack had been installed by a certified mechanic. If it was then it should have a one year warranty on parts & labor, so no worries there.:dontknow:
Still haven't found where the motor oil is coming from (fine mist on passenger side). I'm thinking it's the Accusump. I was going to remove it and the S/C anyway to look for leaks, not that much more work to go for the headgasket.
Here's where I need the help.
Are any of these gaskets reusable? Which ones will I need to purchase (separately or kit)?
Also, I'm going to it back together as close to stock as possible (to minimize conflict at the dealership when I take it in for the "Rack").
So, does anyone have a set of valve covers and possibly intake & thermostat housing for sale, trade, or loan? (will post this in more detail in the "WANTED" section)
