ViperCLKGTR
- Joined
- Jun 3, 2012
- Messages
- 1,097
- Reaction score
- 20
Hey guys, it's been a while. I stopped coming around these parts when I sold my first '06 QC and I regretted it everyday. Finally replaced it and have been on some of the FB groups where I see familiar names pop around. Started having an issue and haven't been getting much traction on FB so here I am crawling back to the ol' haunts trying to find help. I know its pretty quiet around here but I can not figure out this problem with my '06 QC.
Problem: When truck is idling, no matter what gear, it idles under 500 RPM usually in the 300-400 range on occasion it will straight die. Unless my foot is on the throttle it will not idle any higher. Under throttle she runs like a top. Here's the kicker on rare occasions it's intermittent sometimes it runs just fine no idle problems, no nothing.
Symptoms:
-Idles under 500 RPM and wants to die
-Alt meter fluctuates between 10-14 sometimes goes under 10 when off throttle.
-Only codes it's throwing are P0141, P0161, P0138, P0158(rear O2 codes and shouldn't be effecting this from what I've been told)
Parts I've Replaced:
-Alternator(3x) from factory Denso, to O'Reily's junk, to it's current JS Alternator High-Output 250 amp
-New Battery(3x) Optima, Interstate regular, Currently running Super Start Platinum AGM
-Rebuilt Viper Specialty Performance ECU
-Rebuilt TIPM
-New TPS
-New IAC
-New Tensioner
I am at a lost! It started off as a wow I need a new alternator, this is alternator issue, wait we may have an electrical problem. To well electrical wouldn't have anything to do with your truck not idling if the truck idles at 750 it never goes under 14 amp. No vacuum leaks. I have added a new JMB CAI to spruce up the engine bay but other than a drop kit the truck is as stock as stock could be. Anyone have any ideas?
Symptoms:
-Rebuilt TIPM
-New TPS
-New IAC
-New Tensioner
