Attn you car audio gurus.
silversrt
Fairfield, Ca
I just bought an Eclipse AVN7000 indash navigation dvd monitor.
I have been doing car audio for years but I figured one of you might have already located the speed sense wire and the reverse back up wire needed for the nav to function properly.I can tap in at the rear taillights for the reverse wire but thats a long way from the front.Does anyone know of a place in the dash area that i can tap into to get the reverse signal i need, as well as the speed sense wire? I would hate to take it in , since i know all the other connection very well.Any help would be appreciated. Bill
Chirp,Chirp,Chirp.:bebored:
Ive got a wiring diagram @ home. When I get off from work Ill look it up! just remind me if I forgot :p
Thanks Bro.That would help alot.
Ill pm ya later as a reminder. Bill
If you cant wait, call 619-390-5650 and ask talk to the owner. Tell him Patrick with the red-srt-10 sent you. He should be able to answer your question. He is the owner of the stereo shop and also a viper truck owner.
-Red
I haven't done this on the SRT-10, but I did with my Durango. For the reverse sensing I did go directly to the taillight, mostly because I didn't have a wiring diagram and wanted to get the install done the same day.
For the speed sensing wire, I tapped into the ABS sensor at the front right wheel. There was only one wire on the Durango (must ground through the chassis/mount) so it was easy to ID. Should be similar on the SRT10.
Good luck!
Thanks Patrick. I wouldnt want to put him on the spot though.He is in business to make money and most shops charge for info.Im sure I can get it from the diagram. Bill
-Red
Thanks! I will post pics when I get it in.
Good luck!
Keysense purple/tan - ignition harness
Power Lock purple/dk. green - driver kick, door harness
Power Unlock same as power lock wire
Lock Motor lt. green 5wi driver kick, door harness
Unlock Motor tan/lt. green 5wi driver kick, door harness
Parking Lights+ white/yel (L), white/gray (R) + harness at top of driver fender
Parking Lights- white/lt. green - headlight switch
Hazards white/orange - hazard switch
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Reverse Light white/lt. green + inside mirror or plug by PCM
Door Trigger see notes - see notes
Dome Supervision yellow/lt. blue or yellow/org + driver A pillar or cluster
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm purple/lt. blue - driver kick, door harness
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock see factory alarm disarm
Tachometer dk. blue/gray ac PCM, orange plug, pin 34
Wait to start see DirectFax document 1091
Brake Wire white/tan + brake pedal switch
Parking Brake dk. green/white - parking brake switch
Horn Trigger dk. green/purple - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Hope this helps...PM me if you need any more information.
Esh
Right on Bro! I will try to put it in after i get off work tonight.I will let yall know how it goes. Bill
Trunk/Hatch Pin N/A
Hood Pin N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Esh
