If you have a RAM SRT-10 that did not come with a RAM SRT-10 OEM Tonneau Cover, you will need 3 holds drilled on each side behind the truck cab, a total of 6 holes drilled into the bed next to the cab. At that location you will need 2 bracket/hinges and 2 base plates (the base plate is attached to the bed between the cab and bed), the 2 brackets/hinges attach to the base plate. You will also need more hardware that is to be attached to the side of the bed (inside the bad on the left and right side of the bed). Holes must be added here to attach this hardware. The purpose of this hardware is for the Tonneau cover shocks to be attached to.
You can contact me at:
[email protected]. I can send you pictures of the hardware you need and where it should be attached. You must have all the hardware 1st. If you are missing hardware I suggest you contact X2 Bulilders, they may have it on some of their salvage trucks.
One of the things that buys don't know is that if their truck did not have a Tonneau cover from the factory they need all this additional hardware and holds drilled into the bed of the truck.
