Best bang for the buck mod on your SRT-10?
Not the most expensive, the best for the money. What's the one mod that made the biggest difference on your truck for what you spent?
Putting my butt in the drivers seat !
The after market Throttle body , SCT tuner and the transmission modified valve body ..which all cost close tot the same amount .. choices choices choices …
Hey that's three lol he said one hahaha
Nice! Do you all still have those mods/tunes installed?
Yes still installed and still own the factory parts with only 9800 miles on them .. Im a pack rat ..
Remember the last post on , what was it ,, emblems , stickers duh can’t remember… Is that something still !
He comes and goes so we will have to wait and see hahaha
Between the after market types of Throttle bodies what kind of power gains or loss differences are documented along with other benefits naturally aspirated engines or stock … Any Dyno results ?
Also the same with other mods like headers , cams and tunes ?
Mines from Cherry Perfomance !
I'd like to but haven't found a good decal guy yet.
There use to be several on here .. No idea who and a long time ago .. Maybe contact Tony at JTVSP.COM … He use to sell some and probably has a connection …
Someone was making decals with VTCOA years ago for the back slider window .. Maybe Jeff knows !
8-10 horsepower dynoed
Cold air kits (actually hot-air kits): NEGATIVE 8-10 dyno on my own truck, BUT impossible to obtain realistic cooling on a chassis dyno without a jet engine or something like it; Best to use a drop-in if you want to (dynoed)
Longtubes themselves +25 dynoed (2005 Viper Car), but my own truck kind of ignored them. Cat-back installed first then Hi-Flows, then Longtubes. All in, 35 would be close...
Shorties 0-5 dynoed SRT-10 RAM
Camshafts: Depends on too many factors. No possible fast answer...Best to match with cylinder head/Induction performance and static compression c.r.
QC Tune A whopping +80 lbs. Ft. UNDER peak torque, dynoed.
Horsepower zero-ish to 10. dynoed
U/D Pulley 8-10 dynoed
Ported Intake: +15 hp, but a LOSS of torque on the way up to peak numbers; dynoed.
Y.R.M.V.
Question on the tune ? Was that based on factory before mods ?
Was the header gain based on just adding headers PreM any other mods ?
Same with adding a throttle body without other mods ?
I’ve never dynoed my truck .. mine has the K&N put on first , I consider it a hot air sucking system …. Then added the Throttle body and the after market trans valve body … Then the SCT tuner . Wondering what or if any HP gains with those mods my truck may or should have gained …
With those things added I could feel the difference and throttle response and shifting but not massive amounts ..
If I decided to go further it would be headers , personally I prefer and like the looks of the short headers and understand they would produce less Hp …. Not sure about torque gains either way but would be interesting and IMO to gain more in the lower to mid range ..
