Billy Boat Catback
Discussion in 'Performance Mods' started by Dr.Bleed, Nov 25, 2019.
  1. Dr.Bleed
    Dr.Bleed Full Access Member
    25
    Jun 18, 2017
    Hey Guys,
    I know there are 1001 threads about this exhaust but most of them are either ancient or not what I was looking for.
    Basically I was thinking about picking up a nice cat-back for my truck and I couldn't find any good sound clips of just the cat-back system itself with the factory heads/mids. I'd probably finish the whole system at some point but I like both the way it looks and sounds, at least the sound of the whole system. I also like the fact the whole thing is T-304 which seems pretty difficult to find.
    Anyway if anyone has any sound clips of a setup like this it would be greatly appreciated.
    Thanks
  2. rottenronnie
    2,837
    186
    Jul 4, 2006
    Calgary, Alberta
    I started with a BB catback. It is something you will buy once.
    I've since gone with their full system (headers, FF cats) and related piping.
    Very deep sounding (as in set off car alarms on a low-speed rumble by)
    No popping on decel
    No droning on the highway
    I don't have a sound clip handy but it IS on this site. If you want loud, look elsewhere.
    GSJake and Dr.Bleed like this.
  3. rottenronnie
    2,837
    186
    Jul 4, 2006
    Calgary, Alberta
    Yes, there is stainless and there is stainless. The guy at the muffler shop said it was the hardest "stainless" system he had ever seen.
    Dr.Bleed likes this.
  4. Dr.Bleed
    25
    Jun 18, 2017
    Not looking for loud, looking for tasteful and from what you described that sounds like what i’d be getting.
    Thanks for sharing your experiences with it! That’s exactly what I was looking for.
  5. AMS3
    AMS3 Active Member
    123
    25
    Aug 8, 2019
    Savannah Ga
    I had Kooks long tube headers installed on my previous truck, do you think they would be good on my SRT?
  6. Jfireboy1
    Jfireboy1 Active Member Supporting Member
    1,013
    2
    Jan 26, 2010
    Miami, Fla
    I have this exhaust... only complaint is where the joints are, the clamps after a while start leaking. You can only tighten them so much. I’ve got them as right as can be and still have small leaks. If the system was put together with flared ends where joints are it would be a lot better.
    505 and GSJake like this.
  7. rottenronnie
    2,837
    186
    Jul 4, 2006
    Calgary, Alberta
    I was lucky enough to get the earlier type with the 3-hole flanges so they do not leak.
    TrailMix likes this.
  8. rottenronnie
    2,837
    186
    Jul 4, 2006
    Calgary, Alberta
    If I had the newer type, I'd find a welder that could replace those with an actual flange and you would have no more leaks.
    Stainless is not hard to weld.
    Slitherbeast and TrailMix like this.
  9. oldcolt
    2,675
    21
    Jul 14, 2008
    Calgary, AB
    No issues with B&B, other than the initial header install......sounds great!
  10. rottenronnie
    2,837
    186
    Jul 4, 2006
    Calgary, Alberta
    Yes, although it's 2019, header manufacturers are unable to transfer bolt hole exhaust port dimensions to production. Even with B&B's "New, and Improved" manufacturing techniques, I needed to use (quality) ratchet straps for the passenger side alignment and a bolt-extender to actually twist #3 flange enough to correct it for being out by almost the entire diameter of the bolt hole. On the upside, once they've been through a few heat cycles, they relax and permanently settle into their proper locations.
    Slitherbeast likes this.
  11. REPOMAN1
    REPOMAN1 Active Member Supporting Member
    2,588
    May 14, 2010
    EDGEWATER , NJ
    I have full bb also . My old truck had mopar longtubes and mbrp . The bb is by far better sounding and no drone .
  12. CaptnCrash
    CaptnCrash Full Access Member
    209
    31
    Jul 1, 2014
    I have a set of MOPAR Performance long tubes and header back system, no cats. I believe they were fabricated by Borla. Even with no cats it's reasonably quiet in the cab [ and I'm old, you know your tolerance for noise is inversely proportional to your age ;-) ] ... I had the tubes jet-hot coated inside and out. I installed with the factory MLS exhaust gaskets. In nearly 15 years the only thing I've had to do is change the exhaust flange gaskets [ header to exhaust pipes ] earlier this year. Put in copper ones this time, they don't leak and will outlast the truck. Everything still looks new. It has a great sound also. This system is 304 stainless. Fits perfect, pretty easy to install.
    I know the MOPAR Perf parts are discontinued, I'm not sure about Borla. If those aren't available, you can always try ARH. Craftsmanship is second to none and they will fit and sound great. Nice thick flanges also. I have one of their complete systems on my Challenger and it's awesome.
  13. Engin89
    Engin89 Member
    271
    4
    Jul 22, 2012
    GA, Somewhere
    Full BB. Installed headers back single hi-flos. The headers went on easy. Both from underneath, bolted first tube than last, the others lined up with a tug. Burnt em in and re-torked. Planned for a v-Band install, but decided bolt on exhaust.
    No leakes. The first thing i noticed when i fired this thing up was throaty rumble and that the sound was all at the back of the truck.....awesome.....and NO drone at speeds. IMHO there is no better performance add on to these trucks.....$$$ yes worth it.
    Psycho1122 and AMS3 like this.
  14. 505
    505 Full Access Member
    46
    11
    Sep 7, 2018
    Orlando
    agreed. this 06 RC I bought used has the full BB system and it's healthy. breathes great.
    AMS3 likes this.
