Brakes
Discussion in 'General Discussion' started by Bobby S, Mar 14, 2019.
  1. Bobby S
    Bobby S Full Access Member
    42
    Sep 21, 2012
    Old Bridge NJ
    Any brakes out there better than stock. Seems to always squeak when braking.
  2. beastmode1
    beastmode1 Full Access Member
    188
    2
    Oct 2, 2014
    Denver, CO
    Hello I use Evolution semi metallic pads on Bmode no squeak and she stops on the dime. These trucks are heavy so my dealer recommended me to use those. You can find them on ebay.
  3. Michael from the U.K.
    Michael from the U.K. Member Supporting Member
    310
    7
    May 22, 2006
    Berkshire in England
    EBC have a range of pads/rotors for our trucks,I use yellows stuff with no complaints.
    GSJake likes this.
  4. beastmode1
    188
    2
    Oct 2, 2014
    Denver, CO
    I am also putting them on my Toyota Tundra Platinum. Alot better than the factory ceramics that I go through fast. Price wise they are comparable.
  5. POWERBRAKEBOB
    POWERBRAKEBOB New Member
    3
    Oct 7, 2014
    The brakes squeal because the Phenolic pistons in the calipers swell tight in the bores, not releasing, and causing the pads to drag forever against the rotors, burning them. There is no "magic pad" . I Used steel pistons to replace the plastic phenolics, and they release instantly. An added benefit is the freed up rotors add 1-3 MPG.
  6. beastmode1
    188
    2
    Oct 2, 2014
    Denver, CO
    Great point.
