Looks odd to me ! The distance seems way to high and where would the possibly make contact ?Looks like yes is my guess
Thanks .. ill be checking those out ...Searched through my notes throughout the years and these are the part numbers I have. I’d check them out when you get a chance, they’re from Energy suspension. They’re all polyurethane, here’s the part numbers and prices depending on where you buy them.
Rear polyurethane bump stops with Brackets- 5.9104G about $120
Rear polyurethane bump stops- 5.9105G about $50
I guess the manufacturers are using some cheap rubber .. Ive never seen any dry rot and fall off as long as I can remember hahaha ..Just the bump stops. Very common for the age of the trucks not to dry rot and fall off. The slapper bar ones do the same.
Cool thanks formthe info ...I think it's just supposed to bang into the rear axle tube since these are equipped with the Dana 60. The other axles usually have a flat pad welded there.
Here's an example I found online on an '06 quad cab:
That yellow colored bumpstop is a type of polyurethane foam. It's not uncommon for them to split or break off with age. That red or black aftermarket rubberized stuff is not really porous. They can be much firmer on impact in solid form, but lasts a long, long time (comparatively).
There's your fun bump stop science. Haha!![]()
For sure. I think this was an in-progress install photo...Looks like a flip kit plate on top of the leaf spring perch.Noticed the bumpstop is much closer to the rears housing than mine is ,, actually a big difference ,,, hmmm ! Lowered !
With the bump stop sitting on top of the axle tub makes me wonder if thats a good thing hahahaFor sure. I think this was an in-progress install photo...Looks like a flip kit plate on top of the leaf spring perch.
I sure will the more info I can put here i can help out others.Good luck let us know how they work out
Thank you!!I sure will the more info I can put here i can help out others.
Let is know when you get them and Diy with pics .... thanks for posting them up ... pretty straight forward install as long as the bolt holes,line up with the originals hahahaI purchased an aftermarket set up since I couldn't find any info or replacement parts. Still waiting for the item to arrive purchased it a few days ago.
