Caliper rebuild
Discussion in 'General Discussion' started by peterjack, Jul 4, 2017.
Car Parts
  1. peterjack
    peterjack New Member
    Jul 4, 2017
    So as some of you know I have been dealing with 2 seized calipers on my 10, today that all ended.
    Starting this morning at around 9am and finished about 3:30pm. In that time I rebuilt 2 front calipers with 2 rebuild kits from JTS Venom Performance. Replaced all pads and all rotors with Callahan X-drilled and slotted rotors. One thing I did not do is paint the calipers, that will be a project for another day. It was raining this morning.
    During the rebuilding of the calipers the seized pistons would not push in with a C clamp or pop out with air pressure. So I did what any carpenter would do, get a persuader. I grabbed my air hammer and put the mason chisel in and broke the piston out. Probably not the best idea, but it worked. Now that the caliper is cleared of the pistons an o-ring washers. I used a Dremel with a fine wire brush to remove surface rust from the cylinder wall of the seized calipers. Washed the calipers down with brake cleaner inside and out, then began the rebuilding process. After a couple more short sessions with the Dremel, the pistons were all operating as smooth as glass. Same scenario for the other side, pretty much.
  2. Silver05
    Silver05 Full Access Member
    507
    10
    Apr 16, 2017
    I want to rebuild mine and I might order the kit from jts, what all did you have to order and do you have any pics
  3. ViperPete
    ViperPete Full Access Member
    2,649
    5
    Aug 4, 2010
    Ocala, FL
    It's a shame that they fail so frequently. I went through the same crap a few years ago. I've never had a caliper fail before and on my ram both did.
  4. mccubbinsjl
    mccubbinsjl Full Access Member
    284
    Aug 2, 2011
    H-Town (sort of)
    i am rebuilding my fronts right now and I have only been able to get 1 of 8 pistons out so far... im going to nap and then get back on it with some new kind of love.
  5. shorty
    shorty Full Access Member
    2,051
    26
    Sep 1, 2012
    Emory, Texas
    Will turn 160,000 miles next week and never had a caliper failure.
  6. Alberta-SRT
    Alberta-SRT Full Access Member
    639
    2
    Jun 24, 2006
    Lawrenceville GA
    Like anything else, lack of use is sometimes more detrimental than constant use. A lot of these trucks sit for long periods of time. Could that be the culprit?
    TrailMix likes this.
