HOT RAM
After many hours of work,I have finally finished the install of my caltracs.It really doesn't take very long,but I cleaned and painted everything under the truck,painted the rotors,cleaned the inside of the wheels,cleaned the brake calipers.I also put grease on every moving part and inside the front and rear bushings as well.Maybe overkill,but that is just how I like to do things.
Everything looks better than new now.
After the final check of all nuts and bolts,I went for a test drive.Using the 1/4 turn adjustment,it still spins a lot,but stays in a straight line now.Seems to ride better and handle corners better ,too.I will try different adjustments tomorrow.
Before re-installing the billet lowering blocks from X-Metal, I used the DupliColor "anodized-look" paint ,red of course.They look SWEET ! I also left the shackle bolts loose until I set the truck down and THEN tightened them up.Truck sits much lower now !!!Rides better,too.
