EvansSpeedEquipment
We have developed an align-boring procedure to repair damaged cam housings. The camshaft rides in the aluminum housing, if the housing is damaged due to oil starvation or excessive spring pressure, you are left with few options. We can repair the damage, and install a coated cam bearing in all six cam housings. The cam bearing inside diameter is the same as the factory 2.093" aluminum cam housing, allowing you to use any stock or aftermarket camshaft. Please look at our albums for photos of the repairs. We will also upload photos of our custom steel main cap and girdle installations.
