SilverThrone654
- Joined
- Oct 27, 2025
- Messages
- 6
- Reaction score
- 12
This is my first winter with this truck and it got down to 6°F while I was at work and upon starting my truck, everything was fine-ish. Shifter felt like jello when switching gears so I let it warm up for about 5 mins before I headed out, after driving for about a mile I got to stop light and while sitting in 1st gear with the clutch in, the truck began to try and drive forward under power. I threw it into neutral real quick however, when I tried to go back into first to get going after the light changed I could not disengage the clutch. The pedal went to the floor without any force, it did return just like normal though. I kept trying to disengage it by pumping the clutch to no resolve until, eventually it randomly let me disengage the clutch and get back into gear but immediately after, the clutch would not disengage and the pedal once again went to the floor with no force. Does anyone have any idea what would cause this? I am assuming its something with the hydraulic clutch system, maybe water in the system that froze up or a bad seal somewhere? Its in the garage now (limped it home in first) so I'm going to try and check anything I can and will replace the trany and clutch fluid as soon as I can. Thanks in advance.
