Dyno'd Today
Discussion in 'Dyno Stuff' started by trussman, Feb 4, 2012.
  1. trussman
    trussman Active Member
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    I dyno'd my truck today. Same dyno as I used when I only had magnaflow and k&n. Previously had 420/469. Put down 500.8/609.1 today. I'll post the sheet when I get home later tonite so save the BS flags for now ;) I now have RP oil in engine, trans and rear as well as cooler t-stat and some RP ice in radiator SCT tune. Much higher than I had expected.
    [​IMG]
  2. SANTEEN
    SANTEEN Active Member Supporting Member
    6,150
    May 25, 2009
    Miami, Fl
    Brother, hate to burst ur bubble, but u didn't add 80 horsepower by some fluids and a t/stat. Dyno operator screwed something up.
  3. 505'sFastestViper.
    505'sFastestViper. Full Access Member
    13,813
    Apr 26, 2007
    Farmington, N.M.
    he says it also has an sct tune now santeen
  4. phxpoolguy
    phxpoolguy Full Access Member
    3,747
    May 6, 2009
    phoenix
    I would have to agree with dumdum. :D
  5. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    Yeh. Thought I had that when I posted from my phone. After Santeen posted I realized I forgot that. Same dyno and same operator from last time. Numbers may be higher than normal but WTH feels good to me ;)
    Once it's back in "season" and track actually does some prep, I will get the true important numbers. Should be in the next month or so.....
  6. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    Vids
    [ame=http://www.youtube.com/watch?v=znFqxqeJfCA]Ram SRT-10 Dyno Run - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=UlCdAYmYx7M]Ram SRT-10 Dyno Runs - YouTube[/ame]
  7. viperhauler
    18,951
    39
    Jul 27, 2008
    i just want to make sure i understand...you changed the fluid and added an sct and t-stat?
    no way, dude. period.
  8. viperhauler
    18,951
    39
    Jul 27, 2008
    and why are you on the back of the rollers??? and all that bob and weave on decel? those boys don't know how to strap a car down!!!
    did you dyno in 2nd gear?
  9. SANTEEN
    6,150
    May 25, 2009
    Miami, Fl
    Oh well ****, that'll do it.
  10. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    Idk guys. I guess the old saying of the numbers don't lie isn't always true. We will see how it does on the track later this year. And I promise it won't be downhill
  11. wesalbert
    9,775
    3
    Feb 26, 2008
    yea, something just doesn't add up.
    do you know what gear he did the pull in? In the videos I hear 3, but it was already moving when the video started :dontknow:
  12. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    Yeh it was in 4th. Not sure if it's screwed up. The guy did several vehicles before and after mine and they all had numbers right about where they shoulda been. Elevation is about 30ft and air temp was much cooler than before. Not really seeing how he coulda screwed the pooch on mine when all the others were right on. Who knows. I'd be glad to take donations for those who would like to send me to JTSVP for some pulls :D I wouldn't even care if it dyno'd 100 lower, I just wanna check out some of his work
  13. wesalbert
    9,775
    3
    Feb 26, 2008
    From what I understand, it should dyno in 5th. That will explain the high numbers.
  14. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    If I'm not mistaken 4th is a 1:00 to 1 ratio. So that would be the gear to dyno in.
  15. wesalbert
    9,775
    3
    Feb 26, 2008
    I could be wrong. It's known to happen :D
  16. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    Don't ya'll believe in :elefant: anymore?
  17. wesalbert
    9,775
    3
    Feb 26, 2008
    Just looked it up. Your right.
  18. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    Sweet. I gotta print this one. Wife will never believe it :D
  19. viperhauler
    18,951
    39
    Jul 27, 2008
    4th on our trans is 1:1 you want to dyno in 4th
  20. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    Green Cove Springs, FL
    did you use the same dyno that BADAMS9 used...that will explain the high hp number
