gearing question. not 4.88's
Discussion in 'General Discussion' started by SRT2SLOW, May 13, 2014.
Car Parts
  1. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    Green Cove Springs, FL
    Question. so with higher hp trucks. would we benifit from 4'10's?
  2. stealth78
    stealth78 Full Access Member
    2,606
    7
    Feb 15, 2012
    MA
    Your title is going to upset Caveman
  3. stealth78
    2,606
    7
    Feb 15, 2012
    MA
    In all seriousness I've been wondering the exact same thing!
  4. stealth78
    2,606
    7
    Feb 15, 2012
    MA
    Have you really dialed in any real good runs through the 1/4 with that much HP? If so what is your trap mph?
  5. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    why?
    no not yet. I dont wana break anything before I move.
  6. stealth78
    2,606
    7
    Feb 15, 2012
    MA
    Because 488's are his specialty!
  7. caveman
    caveman Well-Known Member Supporting Member
    7,500
    25
    Jul 20, 2011
    Western Colorado
    We totally overthink this gearing thing. The rule of thumb should be to match the tire size to the gear ratio, so that you are running through the traps at the top of 4th. Bigger HP trucks can run a bigger tire, and thus use a taller gear. The reason short gears don't work on the track is that they require a shift to 5th gear prior to crossing the line.
  8. moparviper
    moparviper Full Access Member
    908
    Jul 13, 2012
    Shreveport Louisiana
    I might be able to help you out in a couple weeks. I plan to be around 825 - 850 whp. Suppose to be going to the dyno this week and the track this week or next. Currently the truck has 4.56 so I'll let you know how it goes. Depending on where I run out of gear I will be going back to the 4.10s or 3.73s
  9. caveman
    7,500
    25
    Jul 20, 2011
    Western Colorado
    You are running a TH400, correct? What tire are you planning on using? How much RPM do you want to run?
  10. MOD(S)QUAD
    MOD(S)QUAD Full Access Member
    594
    Dec 4, 2013
    Philthy
    Can the '04 rear with the 4.10 be swapped out with the '05-6 with 4.56's or is their more to it ?
  11. caveman
    7,500
    25
    Jul 20, 2011
    Western Colorado
    Hang on, I've seen this asked before. Let me see if I can dig up that thread for you. :D
  12. MOD(S)QUAD
    594
    Dec 4, 2013
    Philthy
    Ut oh....will this make me look stupid ??
  13. caveman
    7,500
    25
    Jul 20, 2011
    Western Colorado
    LOL! No. It's an inside joke. Often, the first thing a new guy will come on here and ask is questions regarding gear swaps. When that happens, I sometimes bump a dozen or so old threads, to encourage them to use the search function. In your case, I think asking a gear swap related question in an active thread about gear swaps makes sense.
    Oh, and to answer your question directly, yes. You can install shorter gears in your factory 4.10 housing. The consensus is to call Devin at Unitrax (http://gounitrax.com), and he will get you everything you need.
  14. moparviper
    908
    Jul 13, 2012
    M&H 32 X12 slick and I'll be shifting at 5800 RPM when the nitrous turns off. I'll run it out to 6000 without nitrous
  15. caveman
    7,500
    25
    Jul 20, 2011
    Western Colorado
    Are you running an overdrive of any sort?
  16. caveman
    7,500
    25
    Jul 20, 2011
    Western Colorado
    You shouldn't need a taller gear. 5800RPM, with 4.10's, and a 16" tire radius, will get you 134mph through the traps. That's fast enough to run low 10's.
  17. moparviper
    908
    Jul 13, 2012
    Talk to Devon at unitrax. He sells a complete kit. But you do need a different pinion bearing
  18. VPRPWRD
    10,835
    Mar 28, 2012
    PA
    Caveman is known for bumping old threads of the same question asked over and over, don't mind him...
    See, he even admits to it :D
  19. moparviper
    908
    Jul 13, 2012
    No over drive. The unknown factor is what don't know what gearing is in the TH400
  20. MOD(S)QUAD
    594
    Dec 4, 2013
    Philthy
    Let me rephrase my question ; it seems at times the grass is greener and the 4.10 guys want 4.56's and peeps making more power wanna go the other way....sooo if was just an easy swap, could someone potentially just find another member with the different ratio and it would be easy peasy to switch em ??
    The whole rear that is ....
