Gen III Intake Manifold Project
Discussion in 'General Discussion' started by rottenronnie, Jun 18, 2021.
Car Parts
  1. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    My Runner-Extension Project on my Gen III Intake has been "looked at" by a few shops since last Fall. They all claimed they could do the mods I wanted (but none of them did).
    The general consensus by the Intake Pros: "The mods will work in a limited RPM range"; which is what the mods I had planned were supposed to do anyway.
    Over the past month, I've decided to leave the Gen III Intake alone and go with a brand new Custom Billet Intake specific to my engine's power profile.
    It will be the most cost effective and performance effective plan as modified or not, the Gen III Intake was originally designed for a 500'ish hp engine and certain restrictions exist.
    A 3 month turnaround to have a Billet Intake designed, CNC'd and welded up.
    I'll post the results as things progress if anyone other than myself is interested. :)
    They say good things come to those who wait.
    Kiwi SRT10, AMS3 and GSJake like this.
  2. Aussie Viper Truck
    Aussie Viper Truck Active Member
    87
    117
    Feb 10, 2019
    Australia
    looking forward to see it.
    Kiwi SRT10, AMS3 and rottenronnie like this.
  3. Sigma-Wildcat
    Sigma-Wildcat Active Member Supporting Member
    826
    105
    Oct 16, 2006
    Perry. Georgia
    Ronnie,
    Looking forward to seeing your results.
  4. Engin89
    Engin89 Member
    274
    8
    Jul 22, 2012
    GA, Somewhere
    And of course pics of the beast.
    Kiwi SRT10 likes this.
  5. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    967
    1,000
    Dec 16, 2019
    New Zealand
    Ronnie will be just a blur
    rottenronnie and AMS3 like this.
  6. Psycho1122
    Psycho1122 Full Access Member
    1,061
    121
    Jan 3, 2010
    I'm watching!!
  7. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Move along...
    Nothing to see here... ;)
  8. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Pretty cool what can be done by juggling port length (tapered or not tapered), plenum volume and shape, entry radius and angle, TB mouth shape, volume and length, entry split design, fuel injector angle, depth, etc.
    "Tuning" at it's finest.
  9. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Bit warm up there?
  10. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Yes- Hotter than Vegas, The Saraha Desert, and anywhere else on the planet, apparently.
    Auggghhhh Global Warning !!!
    We're all going to die!!!
    Just in time to replace the never-ending Covid-19 news drama.
    There is thunder rumbling around outside right now. Ping-Pong Ball sized hail on the way apparently.
    Augghhh Hail!!!! We're all going to die!!!; etc...
    Howz the knees doin??
  11. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    I got the new Nittos mounted on a pair of OEM 22" wheels.
    Sticky little buggers (except right now with the hailstorm outside).
    Now I'll have to change the launch strategy all over again.
    Because they are the "proper" height, they are supposed to be good for a 3-1/2 to 4 mile per hour trap speed increase over the M&H Racemaster drag radials I've been using..
    WOOOHOOO !!!
  12. oldcolt
    2,752
    119
    Jul 14, 2008
    Calgary, AB
    Let's go for a rip!
    rottenronnie likes this.
  13. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Knees are still there. Seem to spend most of my time doing exercises. The rest of the time being lazy. Just been out in the Beast and have prepped for car show tomorrow. I am hoping to start getting some more parts for the truck soon. A catch can and an under drive pulley first then a gear lever that works. Bled the clutch the other day. It made some difference but it still pushes the thrust bearing back and when you push the clutch pedal it's only half there. Have to pump it up to change gear. Even if you rev it in the driveway the pedal disappears. I wonder if the spring is broken? If I drive sedate it is no problem. It only does it at revs.
    Winter is here -3 this morning but nice sunny day 10. Truck loves the cold air.
  14. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Hopefully those two things will let it be dyno tuned to the best. May have to replace head gaskets first.
    Being at sea level it should be good.
  15. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    A Dyno (PROPERLY CALIBRATED FOR A TEST) references SAE J1349 which uses (if I remember) 77F, a little above 29" Hg and zero percent humidity. This also kinda-sorta approximates seal-level by default.
    So...If you are testing in a high-altitude area, or a low area, hot or chilly, humid or dry, low or high barometric pressure, the dyno SHOULD provide the same corrected number regardless of where the testing is being done or what the weather conditions may be.
    Many Dyno facilities will use a weather station so accurate information can be programmed into the Dyno before the test.
    Unfortunately if bogus numbers are Input, it also provides a cheat and can drive horsepower numbers artificially high.
    For example: Ambient temperature at the Dyno is actually 75F but the Operator "tells" the Dyno it is 140F. The dyno will use a more aggressive correction factor and spit out a high(er) power number to correct for the hot ambient conditions. That is only ONE of the ways a Dyno (and some people near it) can be fooled.
    The dyno numbers people see (without an Operator fudging any Input parameters) are corrected for sea-level and represent "best case" power numbers.
    Then there are the Dynos themselves with Dynojets being generous compared to say a Mustang Dyno aka "The Heartbreaker" which tends to spit out lower power numbers.
    Everybody makes 1000 horsepower these days anyway, so Dynos aren't even needed anymore. ;)
  16. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    I am not being greedy. It had some previous owner put a 600hp badge on the back. I need to get it there. I am hoping with the coils, leads and Torrie tune on my 100+ RON we can tweak the tune to get it across the line. I don't have an SCT Tuner. My Torrie tune came in a HP Tuner and VCM Suite in my lap top. I have no idea how to use it but I am sure any tuner should be able to make small adjustments. I can change between tunes but the rest is all abbreviations and leaves me cold
  17. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Gooday:
    Tunes created by one Tuner are typically locked files and can't be tweaked by another.
    Dodge controllers (JTEC controllers) used on our trucks are notoriously hard to properly tune.
    The tables that are changed (typically fuel and timing) can affect other areas in the tune that an inexperienced Tuner would swear they "never touched".
    Ignition timing has a direct affect on engine torque. That is where most of the power will come from in a naturally aspirated engine tune. Turbo-gas and Turbo-diesel power gains are often more dramatic as now you can tweak boost and fuel (and ignition timing in the case of gasoline engines).
    The goal is to provide enough ignition timing with your truck's tune to increase torque (cylinder pressure) WITHOUT entering into detonation (engine killer).
    Contact Torrie and explain to him what you have (HP and VCM) and he should be able to assist.
    600+ here we come!!
  18. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    I figure the catch can should help with any detonation issues. I used to take all breathers off my older vehicles and vent to ground rather than pollute the air intake. There's an imaginery 5hp there lol
  19. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    True Dat.
    Oil vapours do have a low flashpoint.
    Our engines don't use a PCV system so a well-designed catch-can helps with pesky vapours and sludge.
    They also keep the oil fresher, longer. I used to think it was blow-by that darkened oil but it's actually heat. Well, it's BOTH, but heat darkens it in a very short time.
