Hi all. I'm having probs with my 2006 ram srt10. Any suggestions would be gratefully appreciated.
The truck has been in and out of the garage for three months now and they can't solve the problem.
Basically the symptom is, when i am driving along, if i hit a pot hole, or a lumpy manhole in the road, the truck starts to lose power.
If the pot hole or say a long ripple in the tarmac is extended, the truck will eventually cut out. (not good when you've got an automatic).
It's almost like there is n lose electrical connection, that is wobbling and therefore losing connection and affecting the trucks power to the point of it cutting out.
The garage has so far, apart from carrying out a diagnostic. Tightened all cables/connections, replaced the tippum, and tippum connector.
Note 1. I also have an lpg system as well, this has also been looked at by both the garage and my lpg specialist, and the problem does not seem to come from there.
Note 2. The problem occurs whether the lp is off or on.
Note 3. The problem seems to be obvious after the engine is warmed up, but this could be my imagination.
