NSDQ
Yeah that would be sick!
Not sure if you were around back " in the day" but there was a huge study with wind streamers and videos of the front of the truck showing wind flow etc, and they proved it quite well that there is vary little ram air effect.
And there was actually more suction of the streamers up and away from the intake vs any of them being " rammed" into the intake...
And even if there was an effect at a 100mph there is something like 1psi of pressure " and you had the proper intake to receive the pressure" you might gain 1psi if your well up and above the speed limit ...
Found and old article on it here are some comments
any reasonably well designed scoop will convert 100% of the air's kinetic energy into a pressure which increases as the square of the speed. At 100 MPH, this would be 0.176 psi, or ~ 1.2%, thus ~9 HP on a 750 HP engine. e.g., because of the squared factor, it would be 0.7 psi/4.8%/36 HP at 200 MPH.
So from the looks of it, the scoop would need to be right at where the ram head emblem is right at the very front of the truck to really have any hope of having a ram-air effect...
OR, you get your scoop up above the laminar flow (Just like the scoops on NHRA Pro Stock cars)
Actually, as mentioned SO MANY times on our site, the stock system works pretty good. Rule #1 for ram recovery, you have to slow down the incomming air charge to obtain pressure above ambient. The right block off scoop in the grill takes a "slice" of high velocity air from a high pressure area and feeds it into the fender well. The air then slows down and gets damed up by the sound deadend inner divider panel (you can see it by looking past and above the headlight assm. w/ a flashlight). This is effectively our "airbox". High volume air, slowed down and trapped. Our filter box has a pre-determinded intake size (which has to be smaller than the intake tube) that draws from this area of SLIGHT ram recovery air that also happens to be as cool as the outside air. Secondarily, the filter box further slows the air by slight expantion. The engine then draws with intake pulses from there.
This is overall a very good design and better than most. BIG airbox, decent expansion of high volume - high velocity air, coolest charge possible and proper length of our intake tube.
Pretty hard to beat.:rock:
I've posted this before on other threads...
Here is a NASCAR wind tunnel High / Low pressure image... Red = High, Blue = Low. Out trucks would be even more dramatic with the more square shape...
No Ram from hood scoop, not ever.
The largest benefit fron this scoop is reducing the "Parachute" effect at high speeds from the engine compartment. It helps the splitter keep the front end pushed down.
Maybe Vararam needs to look into making something for our 10's???????
